  • July 12, 2025, 08:49:59 PM
Author Topic: Strange power curve.  (Read 1458 times)
Offline Ty Marcucci
« on: June 18, 2013, 04:12:10 PM »
I don't have the parts list in front of me, but a few weeks ago I was flying my Magnum Plus when at about the vertical eight part of the pattern, the motor started to slow down. Each lap it went a tad slower, etc. I finally let it land under power as it just could not stay in the air. Had to pull the plug to stop it. Any one have this happen?  At least this time it didn't catch fire... LL~ LL~ LL~
Ty Marcucci
Online Tim Wescott
Re: Strange power curve.
« Reply #1 on: June 18, 2013, 04:35:48 PM »
It sounds like the battery crapping out.
And yes, people will want the parts list, because it could be an ESC with a soft undervoltage, plus the batteries crapping out.
Online Howard Rush
« Reply #2 on: June 18, 2013, 06:02:43 PM »
I had a bad battery that would do this if I overtaxed it.  Flying faster than usual or in high density air (cool, low altitude), or in calm would cause it to wimp out.
Offline Larry Wong
« Reply #3 on: June 18, 2013, 06:52:27 PM »
How or were does someone dispose of bad battery?    ???
Larry
Offline Bob Hudak
« Reply #4 on: June 18, 2013, 07:41:30 PM »
Drop the lipo battery in a bucket of salt water for about 24 hours(away from flammables)for about 24 hours, it will bubble like mad. You can now safely dispose of it in the trash can.
350838
Online Howard Rush
« Reply #5 on: June 18, 2013, 07:43:23 PM »
I sent mine back to the factory.  They said they would replace it under warranty.
Offline Keith Renecle
« Reply #6 on: June 19, 2013, 10:47:48 AM »
Hi Larry, I'm in the process of moving house (bad idea!) and I had a few older lipos that needed to be chucked out. I did not want to throw them with any sort of charge into the bucket of salt water, so I looked around for a load to get rid of the charge. I could not find any load resistors that could do the job in my junk box and then a figured that I have a  number of foam cutters, and I just used one of them. My biggest battery was 4-cell so I just stuck a Deans plug on my longest foam cutters and it worked great. I left the setup somewhere where it could not cause any fires that would hurt anything and just left it. Once they were really flat I still left them the salt water for a few days, and then it's o.k. to chuck these dead lipos in the trash. There are no serious toxic metals in them.
I must say that I was amazed at how much power these batteries of ours have. Even after flattening, some of the cells would recover if the short was taken off, and bubbled for quite a while when put into the salt water.
Keith R
Keith R
Offline Larry Wong
« Reply #7 on: June 19, 2013, 11:15:43 AM »
Thanks Keath I'll try it on my hoop foam cutter, does it get hot enough to cut foam?
Larry
Offline Dean Pappas
« Reply #8 on: June 19, 2013, 11:28:51 AM »
You're kidding me ...
No one is going to suggest putting it in the street, starting a video camera, and whacking it with a long stick with a nail in the end? S?P
take care, All
  Dean P. (with tongue firmly in cheek)
Dean Pappas
Offline Steve Fitton
« Reply #9 on: June 19, 2013, 12:51:13 PM »
I vote for popping the batteries with a .22.  That should do the job.
I remember when the CRC safety handbook recommended destroying retired compressed gas cylinders with rifle fire.  I always volunteered to do it at the lab, but they have some other way to retire and recycle cylinders now.
Offline bob branch
« Reply #10 on: June 21, 2013, 06:16:18 PM »
all you need to do to discharge a battery is hook it up to a motor with and esc and turn it on. No special equipmet needed.
bob branch
« Reply #11 on: June 22, 2013, 12:57:50 AM »
It does if there are enough cells with enough energy, but then if this is the case you could most likely still fly with the pack. It all depends on the problem and number of cells. One of my packs did cut foam for a minute or two but then the voltage dropped quickly. You can connect a motor and esc as Bob Branch suggests but this to me is not as basic as the foam cutter, as I do have a few cutters lying around the workshop. The resistance wire acts like a positive temperature coefficient resistor i.e. the resistance goes up when as the temp rises. Car headlamp globes also work well.....same principle.
Keith R
Keith R
Offline BrianW517
« Reply #12 on: July 17, 2013, 10:26:38 PM »
When that happened to me, I found out that I had fried the motor and the Batt & ESC were OK.  :o
