  • July 14, 2025, 07:37:07 AM
Author Topic: Stopped running after square 8  (Read 1270 times)
Offline Larry Wong
« on: January 21, 2020, 08:30:19 AM »
My plane was not performing well, so I had to try something , or call it a hanger queen. I got extreme and remove control hindge tape, took nose weight out, now it’s tail heavy, set timer for 1.5 minutes and took, its now flying good, so I set timer up to 5.30 minutes and up RPM for 5.2 laps, got better , up RPM for laps of5.1 Now it keeps quitting at square 8.  Is it ESC? Or timer?
Larry
Offline Igor Burger
Re: Stopped running after square 8
« Reply #1 on: January 21, 2020, 09:06:05 AM »
What type of ESC you use? can you see some in-flight data? or reason for quit?
Offline Larry Wong
« Reply #2 on: January 21, 2020, 12:29:41 PM »
My setup is 6c 2700 , ice 50 ESC ,Florotti timer  Sami setup on my Max Bee with no problems .
Larry
Offline Fred Underwood
« Reply #3 on: January 21, 2020, 12:56:55 PM »
The Ice 50 has datalogging.  Turn on datalogging and record.  Look at the amperage and voltage at the time of the SQ8.  The SQ8 has a high draw and could low volt cutoff on a weak battery.  Have all of the episodes been on different or same batteries?  I think what Igor was suggesting above.
Fred
352575
Offline Igor Burger
« Reply #4 on: January 21, 2020, 01:49:30 PM »
Yes, however I do not know Castle ESCs, I just wanted to know if it is Jeti Spin esc, that stores reason for early cut off in every case, so it was easy to check also after unexpected event.
« Reply #5 on: January 21, 2020, 02:33:43 PM »
Hopefully, Ice datalogging was turned on already and the record will be there awaiting download.  Otherwise another flight to see what was going on.
Jeti Spin and Spin Pro have the error codes in the "measure" area for reading on the Jeti box, to expand on how that is available.
Fred
352575
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
« Reply #6 on: January 21, 2020, 05:35:36 PM »
Ice 50 works very close to the limit of its capacity, we have already seen here in Brazil some cases of overheating above 110ºC, it must be your problem. This is one of the reasons we use Talon 60.
If you can send the datalogger file we can help you ...
Rogerio.
Offline William DeMauro
« Reply #7 on: January 21, 2020, 06:22:23 PM »
Whats your low voltage cut off set for? What ESC and timer? If a castle, I set them for a soft cut off and a low voltage of 3v per cell. Yes I know its too low, But as I've written before better to ruin a battery than crash the plane. Are you batteries fully charged and are you positive they are fully charged? Maybe you charged them to storage level by accident? Again I'm just speculating like everyone else here.
AMA 98010
Offline Larry Wong
« Reply #8 on: January 24, 2020, 05:28:22 PM »
This is what I got? What does it mean?
Larry
Online pmackenzie
  • Pat MacKenzie
« Reply #9 on: January 24, 2020, 07:43:18 PM »
Never used this software, but looks to me like there were some early short test flights and two full flights on 6S, but the last 5 were on 5S packs?
MAAC 8177
Offline Larry Wong
« Reply #10 on: January 24, 2020, 08:07:18 PM »
I think that’s what happened, I guess I should try just 6 cell only, and see if it works.  I guess I have to clear the ESC last record.
Larry
« Reply #11 on: January 24, 2020, 08:37:41 PM »
Agree about the flights showing short tests, 2 flights with 6s and the  5s flights.  I haven't used the Castle for a few years so not as fluent as I was.  You can record one flight at a time using a setting with much more definition and actually easily follow the maneuvers.  When you are plugged into the dongle, go about the end of settings and set for high resolution.  You can then run a flight, down load it, and have the next flight erase and overwrite.  It is a little painful or tedious, but I took a laptop to the field and would fly, then look at the data, then fly again.  Also, turn voltage, amps, temperature and other settings that might help you.
You can look at some old tracings here on reply 26
https://stunthanger.com/smf/gettin-all-amp'ed-up!/old-dog-new-trics-old-plane-new-rogerio-fiorotti-timer/
and another here with voltage and good separation of maneuvers reply 7, and one by John Tate in reply 18  and another with some other data reply 25
https://stunthanger.com/smf/gettin-all-amp'ed-up!/another-dog-another-'tric-fiorotti-v4-4-timer-with-accelerometer/
I was able to follow maneuvers in sequence by looking at a finer tracing. You can see throttle, amp draw, voltage drop, and temperature rise with each maneuver.  Then you can see the OH8.  You can record all of the values and then only display what you wish on the graph so that it is not too jumbled.
If you don't want to use a laptop at the field, then record your last flight of the day and look at it at home.
I can probably refresh my memory on the recording settings if needed.  I haven't been using the Castle for a couple of years.
Fred
352575
