Electric Stunt => Gettin all AMP'ed up! => Topic started by: Roger Anderson on July 13, 2010, 08:20:38 PM
Title: Stir the pot
Post by: Roger Anderson on July 13, 2010, 08:20:38 PM
OK, I can't resist, I just have to stir the pot again.   Has there been any progress on leveling the playing field with nitro flyers by making them weigh their planes full of fuel?  If weight and saftey is an issue for electric planes and flying line size, why shouldn't the same apply to the entire flying weight of the nitro guys?  I know this issue keeps comming up but we have to keep fanning the flames until someone takes action and modifies the rules to require nitro planes to weigh full of fuel.
Best wishes and good safe flying,
Roger Anderson
Title: Re: Stir the pot
Post by: Larry Renger on July 13, 2010, 11:38:41 PM
I expect that the rules assume a dry plane, but compensate for the fuel to be added.  A 40 size plane usually weighs 40 ounces or so, and uses 4 ounces of fuel.  128ounces of fuel (1 gallon) weighs about 8 lb. so 1 ounce weight per fluid ounce is close.  The result is that there would be about 3 extra pounds of pull test at most compared to a 30 pound basic pull, hardly likely to destroy a well built model!  I never have heard of a contest being lost because of the pull test, unless the bellcrank exited the wingtip (seen that, been there, not pretty) and this was with the old pull test rules and an ill tempered pilot who jerked on his model because we insisted on following AMA rules.  A well built model should easily withstand the pull test with margin to spare, it isn't that hard to do the structure, nor does it add significant weight.
I hardly think the pull test will decide a contest.  EVER!  I just see this as a non-issue in reality.
Sorry!
Post by: Roger Anderson on July 14, 2010, 07:32:45 AM
I don't believe that the pull test is the only issue here.  Flying line size also comes into play.  I still believe that the playing field should be equaled and that all planes should be weighed at their full flying weight.
Post by: Gary Anderson on July 14, 2010, 04:15:21 PM
Hi guys,
I agree the full potential weight should be considered. Bob is correct if you're using a six ounce tank it should be added to the full weight of the model. I just wonder what would happen if you had a plane that was at the weight for line change size and it created a problem, would our insurance company pay or would they say you where not legal, so its on the person that owns the plane?????? Yes you can be over weight after adding the fuel. I hope most take it on their own to be sure they don't get in trouble??? Gary (Just me, I always use over size lines????)
Post by: Roger Anderson on July 14, 2010, 04:30:40 PM
Thanks Bob & Gary for understanding the points I was trying to make.  For example, Gary's Stilleto would not require .021 flying lines if it were weighed without the battery.  That could also be the case with some nitro powered planes but they would currently be allowed to fly on .018 lines if weighed without fuel.  This is not only an advantage in weight and drag but it is also a safety issue.  The simplest and most accurate way of accomplinshing this would be to have the owner/pilot fill his plane at the weight station before of while the plane is weighed.
Roger
Post by: Dennis Adamisin on July 14, 2010, 08:42:39 PM
In a few more years the issue will be moot...
Post by: Roger Anderson on July 15, 2010, 07:22:24 AM
Good point Dennis - folks are discovering electric and more are switching every day.
