Hi Charles,
Like Bob said, the collet holds beautifully, but do remember to clean the shaft and inside of the collet with acetone or lacquer thinner to remove any machining or storage lubricant, and periodically check the propnut tightness. They work fine on the 3 kilo-Watt Pattern setups on 8 mm shafts!
Dean P.
