  • July 31, 2025, 03:46:37 AM
Author Topic: Turnigy replacement?  (Read 1157 times)
Offline John Rist
« on: August 31, 2011, 08:57:01 AM »
I am currently running a Turnigy 3548-900 in my scale LA5.  It swings a APC 11 x 5.5 EP at 10,000 rpm on a 4 cell Li-Po pack. It burns about 1600 out of the 3000 mah pack for a normal scale flight. I would like to upgrade it to a AXI motor.  What would be the appropriate AXI PN to replace this motor?
Offline Mike Anderson
Re: Turnigy replacement?
« Reply #1 on: August 31, 2011, 09:39:15 AM »
AXI 2826-10 (Kv = 920) is the usual 4cell AXI for stunt.
Mike@   AMA 10086
Central Iowa
« Reply #2 on: August 31, 2011, 09:54:53 AM »
1600 out of 3000, or 2600 out of 3000?  If you're really using just 1600mAh, and you're not using the battery for balance, you can go to a lower capacity pack and lose some weight.
Get an AXI with a similar average power rating as the Turnigy, a similar weight, and a Kv of 900 or better (without looking at catalogs, that AXI 2826-10 may very likely going to deliver the goods).
Offline John Rist
« Reply #3 on: August 31, 2011, 03:12:20 PM »
I need the extra weight for balance.  Scale aircraft tend to be tail heavy (short noises big tailes).
