  • July 19, 2025, 10:16:49 AM
Author Topic: Spinner supplier for electric  (Read 1163 times)
Offline TDM
« on: July 01, 2020, 12:10:10 PM »
Vector 40 has a 1-3/4in spinner. I need one with 5mm adapter. I like the bullet shape like the one in the plans.
Offline Brent Williams
Re: Spinner supplier for electric
« Reply #1 on: July 01, 2020, 12:22:53 PM »
Hobby king has a 48mm spinner that might work for you.
https://hobbyking.com/en_us/spinner-48diam-5mm-shaft.html
Offline Wolfgang Nieuwkamp
« Reply #2 on: July 01, 2020, 12:37:35 PM »
If you have an available backplate, you could make the wanted design shape with 3D printer technique.
I created an stl file, sent it to a 3d printer company, and they made it for 20 bucks....
Wolfgang
Offline TDM
« Reply #3 on: July 01, 2020, 01:17:45 PM »
Brent that one is perfect shape but the reviews are awful. I saw a Brodack spinner that is very nice but I cant find a proper adapter for it. I searched the forum for information but it seems elusive at this time. I saw someone putting a Brodak spinner with some kind of adapter but there is no reference to that part.
Wolfgang I do not trust printed parts because they fail at lamination and I do not have a 3D printer.
Offline Dave Rigotti
« Reply #4 on: July 01, 2020, 01:46:39 PM »
Great Planes makes a 1 3/4" dia plastic spinner with a aluminum backplate.  You'll need an adapter for it. I use Hyperion HP-ADAP-50XL.
5mm motor shaft with a 6mm prop shaft.  You NEED the 50XL, not the 50L.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #5 on: July 01, 2020, 01:49:23 PM »
TruTurn.
« Reply #6 on: July 01, 2020, 02:59:11 PM »
The spinner is not made by the familiar home 3d printer with a PLA filament! It is made by Selective Laser Sintering, SLS, using polyamide PA 12 or PA 2200. Rock solid!
Wolfgang
« Reply #7 on: July 01, 2020, 09:50:14 PM »
I print mine from ABS.  Works a treat.
