Electric Stunt => Gettin all AMP'ed up! => Topic started by: Larry Wong on October 02, 2012, 06:53:48 PM
Just had a thought on the Tru-Turn E-Spinners with cooling does the back plate pull air thru if you use a pusher prop? or does it matter? ???
Tru Turn sells spinners that have a reversed cut for pusher props. Just tell them you need it for a pusher prop.
