  • July 31, 2025, 11:13:43 AM
Author Topic: power system for banshee  (Read 2220 times)
Offline Rob Roberts
« on: March 29, 2009, 03:24:46 PM »
Just bought a Sig Banshee 510sq inches what would be some good battery and motor combinations?
Alan Hahn
Re: power system for banshee
« Reply #1 on: March 29, 2009, 04:26:09 PM »
I am sure my Nobler setup would work ok---Scorpion 3020 (kV~880 rpm/V) Outrunner Motor, Castle Creation Phoenix 35A ESC, JMP-2 or Ztron timer, FMA 4s2100mAHr battery pack.
Mike Anderson has a Twister Setup in this link which would probably work well too in a Banshee.
http://stunthanger.com/smf/index.php?topic=12003.0
Others will chime in soon too I bet!
Offline Rob Roberts
« Reply #2 on: March 29, 2009, 05:00:33 PM »
Thanks Alan. Do you think the new Scorpion SII-3014-830 is to small and is 830kv to low?
Offline William DeMauro
« Reply #3 on: March 29, 2009, 05:35:10 PM »
For about 10 flights I had this in my banshee
APC12x6 then electric Prop, Scorpion 3020-14  http://www.neoplanes.com/radio-control/scorpion-3020-14-brushless-motor-outrunner .Battery 4S 4000mah,Phoenix 45 in Gov mode(no set rpm at that time). Plane flew very well on it. I could have used a lighter battery(something like a 4s 3000 or so would have been sufficient.) First plane I tested a Will Hubin timer on. This setup was moved to my P40.
I also flew it with an atlas 2921-08 for about 10 flights Same everything else except I used a JMP timer. Currently this plane is sitting without a power system. This power system but with Will hubin timer in SET RPM now has over 80 flights on my ARF Cardinal.
AMA 98010
Alan Hahn
« Reply #4 on: March 29, 2009, 06:56:45 PM »
For a 4s battery and a 12-6 prop running in the 8-9000 rpm range, the 830 kV should be fine.
« Reply #5 on: March 29, 2009, 07:00:38 PM »
Turnigy 35-36-1100 motor using 10x5 APC-E prop
Phoenix 35 ESC in CL governor mode set to about 10,300 to 10,500 RPM
Will Hubin Timer
4Sx2350 battery
Recommend .015"x 61' to 63', Above set-up should put you areon 4.9-5.2 sec per lap - not a bad speed for the Banshee!
« Last Edit: March 30, 2009, 10:18:26 AM by Dennis Adamisin »
« Reply #6 on: March 29, 2009, 07:37:47 PM »
Its amazing all the different setups we can come up with to fly the same plane and its also amazing that all will provide satisfactory results for most. We all agree on one thing and that is the Phoenix ESC.
AMA 98010
Offline John Cralley
« Reply #7 on: March 29, 2009, 08:36:37 PM »
I further agree the Castle Creations Phoenix ESC is the way to go. Shop around for the best price -- there can be a big difference form different sources. Also, get the PC programmer adapter. It runs around 20 bucks (or find an RC or fellow C/L guy who will lone you one). It only takes a few minutes to program the ESC with it.
John Cralley
AMA 52183
Central Illinois
« Reply #8 on: March 29, 2009, 08:37:38 PM »
ROGER that!
I don't think the motors are all that different but the designations are a little hard to dechipher.  I keep hanging on to higher kV motors too, and IC sized props (i.e., the Banshee would normally fly on a Fox 35 with a 10x6)
Alan Hahn
« Reply #9 on: March 29, 2009, 09:09:54 PM »
ROGER that!
The only thing to keep in mind is what prop you want to use and an approximate rpm that you want to run at. I always use, for the first approximation, the rpm and prop I basically ran with a glow engine. That will set the kV and #cells needed in the battery pack.
Let the rpm target = 0.8*kV*battery voltage ( use ~10.5V for a 3s and 14V for a 4s) sets the rpm level.The 0,8 factor leaves you with surplus for the power in maneuvers.
so if the target is 9000 rpm, then for a 3s battery, you need a kV of at least ~1070 rpm/Volt. If you use a 4s pack, then you can get by with a kV of ~800.
Also note that the 4s battery and 3s battery will have the same overall weight --with the 4s cells being smaller in weight and capacity than the 3s cell (ratio=3/4) --but of course there are 4 of them rather than 3!
These days I am going to larger props than I used with glow, but since they turn slower, I can still use the same motor and battery as calculated above, and simply use the ESC throttle to set the rpm.
« Reply #10 on: March 30, 2009, 05:27:23 AM »
If you want a Phoenix Todds Models seems to have about the best prices on them. The 35 amp is $62.99 and 45 amp is $79.99 http://www.toddsmodels.com/Castle_Creations_ESC_s/39.htm.
I just ripped this from a post I made the other day.
AMA 98010
Offline John Hammonds
« Reply #11 on: March 30, 2009, 05:40:40 PM »
I bought 3 used phoenix ESC's off Ebay, 1 35 and 2 45's the total cost was only a little over a single 45 price brand new. All updated to the latest firmware without any drama using the Castlelink software, not sure exactly how "old" they have to be before you can't update the firmware.
Ebay does have it's uses.  #^
TTFN
John.
BMFA 165249
Offline Rob Roberts
« Reply #12 on: April 05, 2009, 10:34:53 AM »
Thanks everyone for the help and suggestions. I am going with the Scorpion SII-3014-830 a 3300mah 4s battery Castle Creations Phoenix 35. The price from Todds Models for the Phoenix 35 is hard to beat. I am hopping the light motor and battery allows me to mount the battery in the gas tank location with no modifications.
« Reply #13 on: April 05, 2009, 08:25:34 PM »
I think you already know,but watch your CG closely with that plane.Mine was way nose heavy,but then again I was using a brick sized battery. If I ever set it back up I will use a smaller battery or get my battery back over the wing some. That plane was my first try at electric stunt and I made mistakes. It was also originally set up for gas. Good luck with it.
AMA 98010
