I agree on the spars. Adequate for performance but a pain when handling the model. In the past they were even SMALLER! The weight penalty of going bigger is negligible, so I will. Good call, thanks.
As far as the trailing edge thing, the sheeting is really the source of strength in that area, and the stresses are pretty much taken by the spar and ply bellcrank mounts.
How did the Lucky Boxes and control link work out for you?
The power system you quoted sounds like at least equivalent to a .10, probably a .15. I would set the power fairly low for first flights, and maybe only 1 minute or less duration. It took me quite a while to find the right handle spacing, balance point and control horn length. Doing a full 5 minutes, then needing a new battery when you found out what you need to know in a couple of loops is a major bummer.
Once you find that sweet spot, though, competition beware!
