  • July 17, 2025, 08:05:13 AM
Author Topic: Sig Banshee Electric set up question  (Read 2368 times)
Offline Electric George
« on: January 10, 2021, 05:58:13 AM »
Hi All, I have searched Stunthanger and read loads on the banshee and I just wanted to check I was on the right lines with the electric set up as I know things have been moving on at a rapid pace regarding electric motors etc.
I was thinking of an Emax (Arrowind?) 2820/07 919kv with 40amp esc, 4s 2200 lipo ( just because I have several?
 11x5/ 11x5.5 APC prop
I am just going to be learning basic stunts so do not need to fly a whole schedule.
The Emax is available and I have an Emax 2815/07 that I like and so thought I may try another.
Am I on the right lines or is there a better option?
Thanks all.
Re: Sig Banshee Electric set up question
« Reply #1 on: January 10, 2021, 06:18:03 AM »
George,
Your system selections should work fine on the Banshee. Since you are using a 2200mah pack depending on your flight time you might consider clipping the prop diameter to 10.5" ish. with the 5.5 pitch, set the rpm around 10K, would give you around a 4.9 sec lap time on 60' center to center lines. I have a Still Stuka and this is the set up I use with a 5 min, 20 sec set time. You could go to the APC web site (https://www.apcprop.com/) and in the multi rotor section they have 10.5 props both tracker and pusher. I like the pusher as it give a little extra security on outside.
Best,    DennisT
« Reply #2 on: January 10, 2021, 01:25:59 PM »
George,
Best,    DennisT
Thanks, Dennis. Sounds good and that is a useful link to the APC site.
Offline John Paris
« Reply #3 on: January 10, 2021, 04:47:57 PM »
George,
I have an electric Sig Banshee that is currently fitted with a Turnigy 3542 1000kV motor, 11x5.5EP APC prop, CC Phoenix Edge Light 50 and using 4 cell 2600-3000mAh batteries.  I have also used an Arrowind 2815 motor with the same prop and batteries as well as a KR-2 timer and 60A HobbyKing red brick ESC.  These all seem to be able to fly for 5:30 when needed although I normally fly for 4:00 with only one lap between maneuvers for the full pattern and this generally leaves the batteries near or above the storage charge.  Data logging shows that I am pulling around 32A maximum with the Turnigy and 37A maximum with the 2815.
I also use an Arrowind 2815 (920kV) with the 11x5.5EP APC prop in a profile Oriental with 2800mAh batteries in competition running for 5:30.  Normally I need to push a little juice back in the battery after these runs (~200mAh to get the cells to 3.8V) and they are right at storage after full patterns run with 1 lap between maneuvers.  This combination pulls 41A maximum in this configuration.
For reference, the Banshee is a decent flyer.  A friend from Korea used it in 2015 to place in intermediate N30 at Brodak's.  Not too bad considering he had not flown it prior to flying over for the event.
I hope you find some of this information helpful.
John Paris
269
Offline TDM
« Reply #4 on: January 10, 2021, 10:31:03 PM »
My 35-40 size go to set-up JOKER 3548 850KV 11x6 XOAR electric prop 4S2200mAH 35A ESC.
« Reply #5 on: January 11, 2021, 03:25:29 AM »
Thanks everyone. It is so good to have your tips re the banshee and details of what works. I will definitely follow up the advice and look to follow your set ups.
Thanks again.
« Reply #6 on: January 11, 2021, 07:31:26 AM »
George:
The Sig Twister is almost the same plane as the Banshee and I flew mine for two years on a Cobra 2820/12 which is very close to what you have.  I used 4s 2200mAh batteries and an 11-5.5 pusher.  Loved it.
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: January 11, 2021, 09:55:48 AM »
Good day sir,
I have a similarly sized motor on a flite steak. Where do you get the Joker motor? I'd like to convert my primary force
Offline TDM
« Reply #8 on: January 11, 2021, 11:55:55 AM »
Good day sir,
here you go 720W 167g shaft 5mm
https://www.lindinger.at/de/Flugzeuge/Flugzeug-Antriebe-Elektro/Elektromotoren/PLANET-HOBBY-JOKER-3548-4-5-V3-850-KV-BRUSHLESS-MOTOR/9741922
https://www.amazon.com/XOAR-Electric-Airplane-Propeller-Blade/dp/B015GVDGZ8
https://www.ebay.com/itm/372333592294?_trkparms=ispr%3D1&amdata=enc%3AAQAFAAACMBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkd%252F0I%252BERpYfmzqCvv7sUYEkO79nwAUhPKUsOjRvv3AJt6ocrico5V2zAkoN4V0CwgcSNirK9eJjssn1i53A60BTOQley2WCK%252Fi9YDPUBLBgJ0UZTk3zZt29TYaWGBk8sKjAGgJKZluyP6JYhK30YaGxUGrplNGeFLoBtYwfK9m88NonkLT7nwfAstnciim2VEdQeXMpDTZg6OWOvum0dpX7MwxJYBrzW7l0z8T%252FHa4ID3Nw%252FD1ilZfU2svGdEAYRH37qIX5pJZRx2zxSVyaLAYWltxSQ2WdtXp%252FGwDypHzFFI3DzSIWAFzioAHOsHDAq55wN5xDrpVeV0f29AFb%252BqcM%252FFsc35toeTk7Go8VDnV8Qap%252B%252FPsWUKonUpwTgaLzMv2J6REg%252Bo2THm%252Fy%252BWL%252Ftm9pOpI%252BP4Q5cpk6YFA88p4CWzSTLcG1x1WsSzHLkle8hDwNau2Wr9TJZhLmxRxSMPouLteQGbldY8J6oeJuazFPV%252Bb1cO4%252B5RAxxazLl5syB2qhO3MzFCy5w0o4BdQFVTROpUTvJcLmdTRFcUTbXXWEnArzpB%252FFJpAGMsTkOqddNeSFG3etJxcqQfPxKqO3KhkiyJXw3eTlUQdsY6Ynk%252BsnaezSCKvUML4uTxN8yWSAi1GKOVAaNU87kfMgSk%252BrfZp2EiPCij4hiATJvxT%252BTll%252Fkbp8fPdvvJGyh15mmhNUsP%7Ccksum%3A37233359229494aed41d8def49a393e4bdecede2e39b%7Campid%3APL_CLK%7Cclp%3A3268220&chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=372333592294&targetid=1098102009964&device=c&mktype=pla&googleloc=9010790&poi=&campaignid=11774733487&mkgroupid=113829509425&rlsatarget=pla-1098102009964&abcId=9300474&merchantid=112301579&gclid=CjwKCAiAi_D_BRApEiwASslbJ84BW9r9CFTdzvywi0UlVpOwj_xzs8guzEFbbS8DKnY6eybGEKjb0BoC91wQAvD_BwE
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: January 11, 2021, 12:29:38 PM »
The specs look fantastic for a 35 sized plane on 4s. Thank you.
