  • August 01, 2025, 09:30:58 AM
Author Topic: Electrics taking over again  (Read 912 times)
Offline Archie Adamisin
« on: August 10, 2009, 10:07:26 AM »
I know this is a bit off topic, but I was reading through RCgroups and this weekend in Germany there was a new record set in F5D electric pylon racing.  55 sec for 10 laps on the FAI course.  The same pilot did a 53 but is was disallowed because the pilot didn't hook up the 1000 watt-min limiter required in this event.  The airframes are 15.5 sq dm (around 225sq in wings) in size and weigh 1Kg (2.2lbs).  The current F3D glow powered record in 56 sec.
Here is the link
http://www.rcgroups.com/forums/showthread.php?t=1089239
Go to the videos and listen to the 3300Kv in-runners on 5S go.  They are over 220 mph in the straights.
So once again, electrics are taking over.
Archie Adamsin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Re: Electrics taking over again
« Reply #1 on: August 10, 2009, 09:41:19 PM »
Dennis,
That's wild, so much for quite electric, it's screaming!! Need to work on quite props at that rpm.
Best,               DennisT
« Reply #2 on: August 11, 2009, 11:18:37 AM »
That is some serious fast stuff,,,,,,
Was talking to Bryan this weekend, he is looking into making a 428 quickie do better than a nelson with electric, I think he has a master plan in works that might be solid.
I just want to get around the darn pylons in less than 1:50 with my 424 Viper! ok so I only have two races in so far,,,,
Yes electric is on the move to be sure,,,
« Reply #3 on: August 14, 2009, 12:37:49 PM »
Mark,
I have my Predator 500 long course time under 2 minutes on 4S.  5S will get me down to the mid 1:30's.  Al this and still @ 3.75 lbs.  Motor 35-48-1100, APC 9 x 7.5 prop, 5S 3000's
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
