CLICK HERE---->    <----CLICK HERE
  • January 20, 2026, 08:39:48 AM
Author Topic: Setting up a Talon 35 and FM-9 Timer  (Read 369 times)
Offline John Skukalek
  • 26 supporter
« on: September 18, 2025, 08:38:23 PM »
I have been reading posts on SH on how to program the Talon 35 esc and a FM-9 Timer to work together.
It's unclear to me what the Throttle settings should be in the Talon and what the proper programming settings are in the FM-9 Timer.
Could someone please share how it's done to achieve a governed rpm?
Online Motorman
Re: Setting up a Talon 35 and FM-9 Timer
« Reply #1 on: September 19, 2025, 11:09:18 AM »
Others will be more help I hope as I've never worked with a Talon. Scrolling through my FM9 I didn't see a choice for the Talon so it might not work too good. Maybe just try the Phoenix new high and see what it does? You might need the KR timer for the Talon. For the throttle, if there's a choice for control line, choose that and go for the highest governor/throttle settings as the rpm will be controlled by the timer.
MM :)
  • 26 supporter
« Reply #2 on: September 19, 2025, 02:38:11 PM »
Thanks for your reply Motorman.
My FM 9 programmer does have an esc mode option "Talon High RPM".
Offline CircuitFlyer
    • www.circuitflyer.com
Paul Emmerson
Online Motorman
« Reply #4 on: September 19, 2025, 06:01:47 PM »
My FM9 timers are older units. Glad yours has the right setting.
  • 26 supporter
« Reply #5 on: September 19, 2025, 07:13:24 PM »
Thanks for that link Paul. It's great information. I have a Phoenix that I am learning to use.
However the Talon esc seems to work differently.
Online Brent Williams
  • 26 supporter
« Reply #6 on: September 20, 2025, 02:43:43 PM »
Hi John, Your Hubin programmer box has the updated chip for working with the Talon ESC.
I have attached a few screenshots from the CastleLink from the last time I used a Talon 35 ESC / FM9.
Looks like I was using a 4s battery with a 980kv motor for this particular setup.
« Last Edit: September 20, 2025, 03:52:00 PM by Brent Williams »
  • 26 supporter
« Reply #7 on: September 20, 2025, 06:29:17 PM »
Thanks Brent! I think this is exactly what I am looking for. I was trying to set the Talon on "set RPM" and looking for the 3 rpm options in the FM - 9 programmer as I do with the Phoenix esc.
Your Talon setting was "Governor High" and I'm guessing that you just enter the rpm desired in the FM 9.
  • 26 supporter
« Reply #8 on: September 20, 2025, 08:54:09 PM »
Correct.  You program the FM-9 timer to the desired flight duration and RPM with the Hubin FM-9 Programmer Box.
