  • June 26, 2025, 04:23:54 AM
Author Topic: Schulze hook up  (Read 704 times)
Offline Darkstar1
Schulze hook up
« on: December 30, 2010, 10:44:03 AM »
I just hooked my 1846 F2B controller to my Plettenburg. Plugged the power pole heard beeping, pressed button, waited for motor to go but no go. What am I missing? Everything seems to be connected right.
Later,
Evolve or get left behind!
Offline WhittleN
Re: Schulze hook up
« Reply #1 on: December 30, 2010, 11:57:48 AM »
BEC
Norm
Offline Darkstar1
Re: Schulze hook up
« Reply #2 on: December 30, 2010, 12:58:58 PM »
Where Do I get a BEC from. I forgot about that!
« Last Edit: December 30, 2010, 01:20:34 PM by darkstar1 »
Later,
Offline WhittleN
Re: Schulze hook up
« Reply #3 on: December 30, 2010, 03:01:27 PM »
Darrell
Are you using the FM-9 Timer?  If so, Will sells a timer board with a voltage regulator on board (BEC).  what you have to do is solder a couple of leads into incoming (+/-) wires of the ESC.  Castle Creations sell a good one if you are using someone else's timer.
Norm
BTW - been there done that
Offline Darkstar1
Re: Schulze hook up
« Reply #4 on: December 30, 2010, 03:51:57 PM »
Just came from LHS and picked up a Castle BEC. Now I just need a FM-9 timer card from Will.
Thanks.
Later,
