  • July 29, 2025, 08:32:26 AM
Author Topic: Sanyo 1100SCR vs. Eflight 1500  (Read 1481 times)
Offline Mike Palko
« on: August 09, 2007, 09:32:22 PM »
Hi Will,
   I am answering this question in a new thread because I want to keep the battery capacity vs voltage thread on topic.
   Your question is a tough one because neither the Sanyo 1100SCR cells or the Eflight 1500 cells are made to take the punishment you are putting them through (73C and 53C discharge respectively). Because of this it may be a waste of time to go into any detail about each cell. Try your best to keep them cool and keep the flight as short as possible.
   With that being said, in my opinion you will get better performance from the Eflight 1500 cells because they are the best in the 2/3A class. They are also smaller and lighter than your 1100 cells (an added bonus) and would be a fresh cell, rather than your old 1100 cells, which sound like they aren't going to deliver their max performance anymore.
   The Eflight 1500 cells can be found at www.cheapbatterypacks.com for $2.50 a cell along with a discharge graph. They are also reviewed in the September issue of Quiet Flyer.
   As for the cell condition you may have over charged some cells (HOT) and not fully charged others (cold). If you want to find out their true condition you can try charging them at 1/10C or .11amps until the pack is fully charged or better yet charge each cell individually. Once fully charged, discharge the pack or cell(s) to find what kind of capacity it is delivering. If it is considerably less than 1100mah your cells are shot.
   If I were you I would buy new cells knowing it is a fairly cheap investment for a fresh start. But, you also have to be comfortable knowing you may trash the cells after a few flight from the high discharge. If you can handle a little more weight go with a larger cell. In the end it's your call.
Offline dynasoar1948
Re: Sanyo 1100SCR vs. Eflight 1500
« Reply #1 on: August 10, 2007, 12:12:22 PM »
Mike,
Thank you for your input.  I'm actually amazed that my Sanyo 1100 SCR cells have held up so well over a nearly 10 year period.  Following six seasons of abuse, they have not been worked with for about  the last three years  (been flying Sport-Jet).  I slow charged 26 of them in series, and cycled several times, then discharged each cell into a 20Amp (initially) load while timing the drop to one Volt.  Typically the cells were either over three minutes  (say 1000mA) or virtually dead on arrival.  Was able to get enough cells to (soon) check out my new Phoenix 80 ESC and maybe get a test flight or two with my new ship.
I'll build up a 20 cell battery with the new 1500 cells, which promises to be 6 oz lighter than my present 18 cell setup, which flirts with overweight disqualification at each weigh in.
Will
William Stewart
