  • June 25, 2025, 12:59:10 PM
Author Topic: Run time  (Read 1700 times)
Dwayne
Run time
« on: January 22, 2011, 05:01:08 PM »
Hi all I know this may be a broad question but I bought a Scorpian 3026 and was wondering how long it would run on a 2250 ma 14.8v battery. I'll be using a 11.5x5 prop.
Thank you
Dwayne
http://www.scorpionsystem.com/catalog/motors/s30_series_v2/SII-3026-890KV/
Online Dennis Toth
Re: Run time
« Reply #1 on: January 22, 2011, 05:46:14 PM »
Dwayne,
This will depend on the amp draw, my guess is this prop/motor will draw around 26-28 amps static. Using the max draw down of 80% would take 1800 mah out and give a run time of just under 5 minutes which will be close on being able to complete the pattern. You can either reduce the static amps of around 20 (reduce prop size) to get about 5m 30s, or increase the pack capacity to 3300 mah.
Best,      DennisT
Dwayne
Re: Run time
« Reply #2 on: January 22, 2011, 06:22:06 PM »
Thanks Dennis, so does this mean that even with a 3300 ma battery I'm only going to get 1 or 2 flights per charge?
Re: Run time
« Reply #3 on: January 22, 2011, 10:30:38 PM »
thats the aim - use the smallest pack possible to give you one flight.
weight is what you dont want  and bigger packs weigh more
5 minutes is not "quite" enough to get through the pattern comfortabley - i'd err on a slightly bigger pack
Dwayne
Re: Run time
« Reply #4 on: January 23, 2011, 05:20:08 AM »
Thank you,  I guess I got things wrong I thought the point here was to have a plug and play system that you went to the field and flew all day with no muss no fuss, so I guess this means I'm taking a charger to the field, how long does it take to charge a battery?
Re: Run time
« Reply #5 on: January 23, 2011, 12:06:27 PM »
Dwayne, it depends on the size pack and what rate you can charge it at.  my 4000mAh packs are 2C and take 45 minutes to charge.
I have 8 packs - so I can fly all day no problem - you can get away with 3-4 pakcs if you are flying with a lot of other people as you get time to charge them in between flights.
Re: Run time
« Reply #6 on: January 23, 2011, 12:49:06 PM »
Whatever it draws static on the ground is going to be considerably more than what it'll draw in level flight (which accounts for much of the pattern).  If you go through enough of the existing discussions on the list you'll find that (a) average power consumption is about 1/2 peak power consumption, and (b) peak power consumption is not too far off from what it draws static on the ground.
So if you'd drain those batteries in 5 minutes of full power on the ground, they'll almost certainly carry you through the pattern just fine, and indeed are probably a bit more weight than you'd like to carry.
Offline Dean Pappas
Re: Run time
« Reply #7 on: January 23, 2011, 01:22:50 PM »
Hi Dwayne,
As you can tell already, one very short question starts a chain of "ifs" and "thens" and a whole bunch of them are necessary to say how long you can fly on a certain sized battery.
In general, though, you do not want to be flying multiple flights on a battery, unless they are quite short.
The batteries degrade terribly if you discharge them too deeply.
One discharge to "dead" turns them to trash, and a handful of discharges to "nearly dead" will shorten their cycle life dramatically.
On the other hand, if you never use the bottom 25% of charge and provide cooling so that they never see temperatures over 140 Fahrenheit (preferably not over 125F) then they will last one or two hundred cycles.
When folks say "plug and play"  that usually means ... plug a freshly charged battery in before each flight!
I hope we helped.
What is the plane, size, weight ... you know: MORE INPUT!
take care,
   Dean P.
Dean Pappas
Dwayne
Re: Run time
« Reply #8 on: January 23, 2011, 02:54:46 PM »
Hi Dean thanks for the input
As stated above I have a Scorpion 3026/890 kv it's in a vector, a Future ESC and will have a Ken Doherty timer, wieghs 40 oz so with battery it should be around 52 oz.
Re: Run time
« Reply #9 on: January 23, 2011, 03:35:22 PM »
Check out the "List Your Setup" thread for similar models.
Or read this thread: http://stunthanger.com/smf/index.php?topic=19275.0, which comes to a whole bunch of different ways of saying two things:
First, how do design your setup:
  • Choose a motor and battery current capability that will deliver a maximum of 200-300 watts/pound (Rudy Taube says 175-200, but others say more).
  • To go with that, choose a battery capacity that will deliver an average of 150 watts/pound for six minutes.
  • Choose a Kv and cell-count combination that'll let you turn about 8000 RPM at 75-80% throttle with fully charged batteries.  For your motor you won't quite get there with three cells; four will give you plenty of overhead.
Second, how to get someone else to design your setup: take the all up weight you expect (52 ounces in your case), and see if your motor manufacturer lists the stuff necessary for 3D RC.  If they do -- use it, or the equivalent parts.
Re: Run time
« Reply #10 on: January 23, 2011, 04:25:51 PM »
the 3026 is a pretty big motor for a vector 40 - you can use the 3020 and save yourself some weight and still have HEAPS of power
I run the 3026 in my T-rex (and Legacy) they are 60" !!!
Dwayne
Re: Run time
« Reply #11 on: January 23, 2011, 08:56:39 PM »
Hi  Wynn I chose the 3026 becouse I have plans for a Time Machine 60 I'm calling the E-Machine, I have an idea on how to build it much lighter than stock so the Vector is for proof of concept and to teach me how to set up one of these lectric thingies... n~ :! #^
Offline Rudy Taube
  • Ret Flyboy
Re: Run time
« Reply #12 on: January 24, 2011, 06:55:13 PM »
    I have started to fly e-carrier and my batteries get pretty warm and am wondering what the definition is when I see "don't charge a hot battery until it cools off". How warm is hot and could you cool the battery down in a cold chest so you could recharge it sooner after a flight?  Eric
Hi Eric,
This is a very good question. It looks like it got lost in the discussion of this posts topic.
The short Answer is:
Before you charge it, it should be cooled down to where it only feels "warm" in your hand (This will be =/< 120 f), NOT HOT TO TOUCH (which is well over 130 f).
Longer Answer:
Like Dean, I, and others have said before: Our batteries can tolerate some abuse but it will cost you by decreasing the # of cycles until "battery death". Recharging them when they are just warm, per above, will not decrease their life very much at all. They do not need to be cold to charge them. But, if you are really pushing them hard and getting them over 125 to 140 f in flight, then you may want to use a cooler to bring them down to at least a "warm" state, or below, before charging.
If you charge them while they are very hot ( 125 to 140+) you will decrease their life BUT the important issue is SAFETY. If you charge them while they are very hot they may have a cell overcharge and cause the battery to burn. This is rare, and easily avoided by cooling our batteries to an =/< warm condition before charging. In the summer a cooler at the field is a good idea, you can use it for the batteries too!  ;)
« Last Edit: January 25, 2011, 02:04:34 AM by Rudy Taube »
Rudy
AMA 1667
Offline Keith Renecle
Re: Run time
« Reply #13 on: January 24, 2011, 10:33:00 PM »
Hi Dwayne,
I have run many .40 size power packages, and my favourite motor is the Arrowind/E-Max 2820 with a 40 amp esc. The battery is a 4-cell 2200 mAh Lipo. For a 5:30 flight my 43 oz. Protron uses around 1400 mAh up at our high altitude and around 1800 mAh at sea level. The prop is the standard APC 11 x 5,5 E, and I use my own governor timer system to keep the rpm constant. The motor runs so cool that I sometimes think that I should use a bigger prop, but it just works so well as it is. There's nothing wrong with "cool!"
The battery use is dependant on how you set up your flight. It only takes 5 minutes or less to complete the full pattern when you fly at a constant rpm, so the level laps go faster. At a constant rpm, like when you use a governor system, then you tend to use a steady predictable amount of power. As the others have stated, you need to use a battery pack that gives you one good flight with an edge to keep the battery happy as well. These days the Lipos can be charged a lot faster, but then you need a more potent charger that can supply many more watts. The standard ~40 minute charge is fine if you have a few batteries, and prices are pretty good right now..........and will get better still!
Keith R
Keith R
