  • July 08, 2025, 08:21:19 AM
Author Topic: RULES I am opening a can of worms  (Read 2513 times)
Offline TDM
« on: March 23, 2010, 08:44:31 AM »
I believe that some rules take us to a disadvantage over Wet Set up  R%%%%.
Why are they allowed to weigh the plane empty while we are required to put the battery on board  HB~> HB~>. I think we should have a weight credit of 4 or 6oz based on the size of the plane. And the size of the plane should be driven by wing span. Most 40, 60 etc size stunters are in a certain wing span range.
Offline Dean Pappas
Re: RULES I am opening a can of worms
« Reply #1 on: March 23, 2010, 10:33:50 AM »
Hi Dorin,
Yes, it is a can of worms! The F3A guys are waging the same losing battle as we speak.
Yes I say "losing" in passing, without making much fuss: only because ...
I believe we still possess a great advantage in that we have better consistency and the potential in the near future for better-behaved horsepower than any wet setup ever devised #^ S?P
Dean Pappas
Dean Pappas
Online Matt Colan
« Reply #2 on: March 23, 2010, 04:14:13 PM »
I think it is because on a wet setup, the fuel gets burned off during the flight, which lowers the weight of the airplane.  If it weighs 50 ounces dry, and you have a 5 ounce tank in it, the plane weighs 55 ounces, but during the flight, fuel gets burned off and at the end of the flight, the plane weighs 50 ounces again.
« Reply #3 on: March 23, 2010, 05:10:28 PM »
the pull test should be eliminated all together - it causes mor damage and breakages to planes than would happen in normal flight
You dont have to stress your airplane past the limit in RC - so why do we have to do it with CL?
Offline Peter Mazur
« Reply #4 on: March 23, 2010, 07:50:54 PM »
In the electric rules for Carrier, we weigh electrics with batteries but pull at 20g for Electric Class 1 and 2, compared to 25g for Gas Class 1 and 2, and at the same 20g for Gas and Electric Profile. This is setup more for the convenience of the contest management, rather than having, for example, 25g pull for Class 1-2 gas and 21.3g pull for Class 1-2 electric. I understand stunt guys are really, really concerned about weight, but it is hard for me to understand that a 10% increase in required pull test would make more than a 1% increase in model weight. I'm really, really concerned about safety. I consider the pull test my best friend. If you have ever stood outside the circle when my Class 2 is flying high speed, either electric or gas, you might consider the pull test your best friend, too.
Pete
« Reply #5 on: March 23, 2010, 10:45:22 PM »
Can you justify this assertion with analysis?  I think you may have a misunderstanding of the nature of materials.  The wood and wire we use should be within their elastic limits (is that the right term?) during a pull test, so they should be good for thousands of pull test cycles without degradation.  The pull test does force you to build your airplane with a safety factor, which is prudent anyhow.  A pull test will discover unseen problems like kinked lines, which could cause you to lose an airplane.  That happened to me at a stunt contest a couple of years ago.  It saved me about two years of building.  All I had to do was change lines when one broke during the test.
« Reply #6 on: March 23, 2010, 10:59:30 PM »
I can think of only 1.0 stunt flyer capable of designing a stunt plane accurately enough to withstand a pull test with an empty tank, but not a full tank, and I don't think he would.  I doubt if Dorin is worried about the wimpy stunt pull test.  More of an issue is the break between .018" and .021" diameter lines.  I think there's a rule proposal to increase the model weight for the .018-.021 threshold.  If not, Dorin picked the worst time to think about a rule change: the proposal deadline was a week ago.
Offline TDM
« Reply #7 on: March 24, 2010, 07:01:08 AM »
Howard that is absolutely right. It is the line thickness that is the issue. When a wet set up will get away with using thinner lines even though the weigh of the plane at take off exceeds the line thickness weigh, meanwhile we get penalized and are stuck with the thicker lines. And I believe this rule is just for convenience of not having a bunch of planes at appearance judging with fuel on board dripping all around hence we should get the credit for the fuel we would otherwise have on board as if our ship was a wet setup which would be fair.
I wish I could design a plane like a F1 car right on the other side of the edge of reliability.
Kim Doherty
« Reply #8 on: March 24, 2010, 07:47:34 AM »
Dorin,
I do not think you are opening a can of worms. At the 2006 World Champs in Spain the four electric models were weighed WITHOUT the battery. Having said that you do not want to fly a sixty ounce plus model on regular .015 stranded lines. Perhaps the low stretch, high carbon Russian F2D lines or .014 solids but anything less will not let you have good control in the wind.
Why you should not include the weight of the fuel on board at take off is a questions for Dr. Seuss. It just keeps getting curiouser and curiouser....hmmmmm?
Kim.
Offline Dean Pappas
« Reply #9 on: March 24, 2010, 11:57:37 AM »
Hello Dorin,
Hello All,
Let me put the shoe on thr other foot, if you please.
There have always been "sweet spots" in design: by definition, they live right next door to a bad-spot.
These sweet spots have been defined by conveniently available wood sizes, engine sizes, and now battery sizes.
On the negative side, there used to be a few "holes" in the size/weight/power capability of the better electric motors, but these are being closed up as the market expands.
In the old AMA (not FAI) all-wet world, there was another break-point: the jump from a two-stroke 40 and 0.012"/0.015" lines (solid/braided) to 0.015"/0.018" with just a small increase in displacement.
It speaks to the great suitability of the Tigre 46 for Stunt that we chose it, and the resulting bigger lines, over the best of 40's in large numbers back in the 70's.
Now we have a new set of break-points to add to the design decision, at least for AMA!
I predict that E-designers will be shooting for nothing but 38-ounce and 62-ounce airplanes.
The designs will be sized to force careful building of planes with wings as large as possible for these just-under-the-limit weights.
The centifics versus line size are at their best for the two figures stated.
Just as the RC Pattern guys have encountered, a little inattention in the finish or a repair will now take a plane across that break-point and turn an eagle into a groundhog.
The whole weighed batteried or wet issue needs settling in a sensible way. If the precedent in Stunt is without batteries (as per Kim) then we are golden.
If not, then plane size will drop a few percent, in the future. I realize that doesn't fix your problem, Dorin!
Best to All,
Dean Pappas
Dean Pappas
« Reply #10 on: March 24, 2010, 01:35:06 PM »
I have been living for several years at the .015-.018 break.  I remember flying in the wind at the Nats with my 66-oz., .40-powered model on 7-strand .015s, trying to guess how much control input to put into the rubber-band lines for square eights.  I switched to Staystrate lines (essentially Russian F2D lines), which are stiffer, but hard to get along with.  Now with the new rules I'm flying a 62-oz. .65-powered model.  I have given up and am using .018 lines.  They are easier to maintain, and I'm insured against a miscalibrated scale.  My next stunter will use Kim's King Kong powerplant.  I think I can keep it under 75 ounces, but 64 is pretty optimistic.   Tell your Congressman to vote for CLA 11-22, which bumps the .018-.021 break up higher.
I think that was Dr. Dodgson, not Dr. Seuss.
« Reply #11 on: March 24, 2010, 05:57:58 PM »
Yeah, Matt, but it still weighs 55 ounces at launch. The pull test should reflect that.
Bob Hunt
,,,,,,,,,,,so, at the end of the flight gas & electric are equal.  What could be fairer?
Offline Dean Pappas
« Reply #12 on: March 24, 2010, 07:07:49 PM »
Hey,
It's Bob back from the great SouthWest!
I really see no reason why we should'nt weigh everything "ready for flight". That means full of fuel or with batteries. If you heap blessings upon your airplane prior to flight, then they should be added as well.
This has been proposed in the RC Pattern world as well, and theeeen the next argument becomes whether to raise the weight limit(s) for everybody. Remember that an overweight RC ship simply gets zero'ed. Fat lines aren't such a bad penalty!
Curioser and curioser ... definitely Dodgson ... but he was a perv anyway.
later,
Dean
corrected later D.P.
« Last Edit: March 25, 2010, 07:24:34 AM by Dean Pappas »
Dean Pappas
« Reply #13 on: March 24, 2010, 09:00:05 PM »
Just go back to Deano's reply #1, the empty tank versus full tank issue will be moot before long...
Offline jim gilmore
« Reply #14 on: March 24, 2010, 09:26:29 PM »
So, how much does 4 ounces of model fuel weigh ?
Offline TDM
« Reply #15 on: March 25, 2010, 08:25:32 AM »
Is this a Dough question?
Can of worms it is.
All I am saying here is keep the rule as for weight line size. Then make the weighting part of it fair.
Option one: Electric has credit for fuel on boar on similar size plane.
Option two: If we have to have the battery on board then they should have fuel on board too.
