  • July 10, 2025, 04:18:24 AM
Author Topic: RSM Electric Take Apart Ringmaster  (Read 968 times)
Mike Griffin
« on: February 25, 2013, 10:33:04 AM »
Please click this link to go to the building thread of this model.
http://stunthanger.com/smf/index.php?topic=30420.0
Offline Larry Renger
Re: RSM Electric Take Apart Ringmaster
« Reply #1 on: March 03, 2013, 03:59:27 PM »
Andy Borgogna just flew his kit "proof" model, and it looks like a winner right off the board.
Offline ericrule
« Reply #2 on: March 03, 2013, 07:49:35 PM »
I met with Larry & Andy on Friday for test flights. Too windy but got a couple of pictures.
The first is our intrepid builder/tester Andy holding the test model. The second is a shot of how Andy designed a battery holder to fit under the wing.  The holder is very simple yet it works perfectly. Please note the small "X" on either side of the battery. This mark the C/G on the model. Andy moved the battery back and forth until he got a perfect balance. He then marked the location with a line on the battery. All he has to do is to match up the line with the C/G marks and he has a perfect battery location when he replaces the battery. In my opinion this shows how creative Andy is. The system is very simple yet it works perfectly!
Offline Robert-Jan
« Reply #3 on: March 04, 2013, 04:12:18 AM »
Can you tell me more about the nose.
It looks like a take appart nos  ???
Greetings Robert-Jan
« Reply #4 on: March 04, 2013, 08:11:52 AM »
Yes Andy is one of the good guys and very ingenious.
Offline ericrule
« Reply #5 on: March 04, 2013, 09:53:13 AM »
Hi Robert:
A quick answer is No.
From your question I am assuming that you see where the fuselage bottom is cut and shows in the picture of the bottom of the wing. The wing has a plywood center rib that slides up into the upper fuselage. That rib is held in place by three bolts in the fuselage. The bottom of the fuselage is glued to the wing bottom and there is a small notch at the front which slide into the center of the fuselage front end to lock the parts into place. The fuselage is a solid unit from nose to tail. The wing, stabilizer/elevator and fin slide into it and are clamped down by means of bolts through the fuselage. This results in a structure that is light in weight, extremely strong with no tendency to twist under flight loads.
Offline Andrew Borgogna
  • Andy
« Reply #6 on: March 04, 2013, 03:44:42 PM »
You may have noticed that I have kept my nose out of this discussion.  But I must admit I was quite pleased with yesterdays test flight, right off the board I was able to do everything in the OTS pattern without a hitch.  One weird thing to report, the battery hold down popped off the plane when I was removing the battery after the flight.  This morning when I started the repair I notice something I had never seen before, the epoxy holding tie downs had never completely hardened.  It was 5 minute epoxy that I had used many times but for some reason it only hardened completely around the edges.  I think it might have something to do with applying the epoxy over the doped covering material before the dope had enough time to completely dry.  Today I removed all the covering material where the hold downs are attached and then saturated the balsa with thin CA.  I removed all the epoxy from the tie downs and glued them with 30 minute epoxy.  I have used this method for tie downs and several of my electric planes and never had this problem.  I am just thankful it didn't happen while flying.
Finally thanks for all the nice comments I think this plane will be a lot of fun to have, lets face it we all at one time or another had a Ringmaster and this plane flies like a Ringmaster.
Andy
Andrew B. Borgogna
