  • June 20, 2025, 08:57:42 AM
Author Topic: Wood pusher props - Zingers  (Read 2514 times)
« on: October 15, 2009, 10:17:42 AM »
Guys,
For those of you that like to carve and shape their props I have found that Zinger has a full line of wood pusher props (or as some say "prop kits") about the same price as the APC's so you can take your choice. I have flow the prop a couple times and it has very good thrust due to it's thickness, amps are a little higher then the APCE but that's in stock condition.
http://www.zingerpropeller.com/Pusher.htm
Best,                DennisT
Tags: props
