  • July 12, 2025, 04:56:25 PM
Author Topic: Ringmaster trainer II E Build  (Read 1452 times)
Offline pat king
    • PDK LLC
« on: February 18, 2013, 10:31:23 AM »
This is the basic wing for the Ringmaster Trainer II. The basic wing for the fuel powered airplane and the electric airplane are the same. The only difference in the finished wing for the two airplanes is the front wing locating block is 1/16" further away from the centerline on the fuel powered wing. This is caused by the 1/8" doublers on the fuel powered version and the 1/16" doublers on the electric version.
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: Ringmaster trainer II E Build
« Reply #1 on: February 18, 2013, 11:57:28 AM »
Here is the assembled fuselage and the assembled and primed wing. The fuselage needs to be filled, sanded and primed. The wing needs sanding filling and sanding, then another light coat of primer.
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #2 on: February 20, 2013, 02:13:50 PM »
Here is the finished wing. The fuselage filler is the fuselage color.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: February 21, 2013, 08:52:14 AM »
Looking good.
Offline pat king
    • PDK LLC
« Reply #4 on: March 05, 2013, 02:40:02 PM »
Here is the fuselage with the powertrain, bellcrank, and gear mounted. The Bellcrank is on the inside to keep it out of the way of the battery.
Pat
Pat King
Monee, IL
AMA 168941
Offline John Cralley
« Reply #5 on: March 05, 2013, 02:57:18 PM »
Nice Pat,
As I look out the window here in Illinois, I think you need to replace the wheels with skis!!!  y1
John Cralley
AMA 52183
Central Illinois
Offline pat king
    • PDK LLC
« Reply #6 on: March 05, 2013, 09:04:40 PM »
John,
It won't need skis if hand launched, but the "landings" would be ugly.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #7 on: March 06, 2013, 12:06:05 PM »
Here is the finished airplane. The web strap that goes around the wing and battery is not on the airplane. The strap is to ensure the battery and airplane do not part ways in a negative G environment.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #8 on: March 14, 2013, 04:40:26 PM »
I weighed the airplane. With battery it weighs 37 oz.  y1
Pat
Pat King
Monee, IL
AMA 168941
