  • June 18, 2025, 06:13:28 AM
Author Topic: a simple question  (Read 686 times)
Offline Chris_Burgess
a simple question
« on: January 09, 2013, 01:09:45 PM »
How do I get in contact with will hubin to purchase one of his timers, and if he's on here, feel free to self promote.
Offline Crist Rigotti
Re: a simple question
« Reply #1 on: January 09, 2013, 01:21:25 PM »
whubin@kent.edu
He's a member.  Search "Will hubin" in the members search.
Offline John Cralley
« Reply #2 on: January 09, 2013, 07:18:27 PM »
Chris is correct. In the past Will has been willing to work with you to make sure you get the correct timer for your application and his prices are very reasonable (about $10 to$20). You can also buy some of his timers from Brodak but the price will be a bit more.
If you are thinking of doing a number of electric models then his FM-9 system is the way to go. The initial cost is fairly high but then additional timers are about $10 - $15 each and easily programmed for your application.
John Cralley
AMA 52183
Central Illinois
