  • July 29, 2025, 09:25:37 PM
Author Topic: Ringmaster Fly-A-Thon  (Read 2643 times)
Offline John Cralley
« on: October 06, 2008, 09:24:00 PM »
Check out the Ringmaster Fly-A-Thon Thread in the "Events" category. I flew my two electric Ringmasters and my daughter Beth soloed with my original electric RM. It is now in the rebuild bin!!  :'(
John Cralley
OOPS!! Guess I bent the rules a bit too far and Sparky pulled my plug. The Events post is history!!!! LOL
« Last Edit: October 08, 2008, 05:52:39 AM by John Cralley »
John Cralley
AMA 52183
Central Illinois
Alan Hahn
Re: Ringmaster Fly-A-Thon
« Reply #1 on: October 07, 2008, 07:45:52 AM »
That looks great! Have you already posted the details of your setup (sorry--memory cells are going, going, gone....)?
« Reply #2 on: October 08, 2008, 05:42:05 AM »
Alan,  I posted the basic setup a year or so ago but I don't remember in which forum and anyway things have evolved since then. I'm off on a vacation for a week or so in about an hour. I will get the info together and post it when I get back. If you note the gray hair you can guess that at 76 I have lost a lot more neurons than you! LOL
John Cralley
AMA 52183
Central Illinois
« Reply #3 on: October 08, 2008, 06:00:25 AM »
The Ringmaster Fly-A-Thon results are posted in other forums but the overall # of flights were 249 in four different countries. Jim Swearingen, my daughter Beth and I flew at "Hobby Hideaway" in central Illinois. We made 15 flights with seven different Ringmasters (two of which were my electrics).
John Cralley
John Cralley
AMA 52183
Central Illinois
Online Dennis Toth
« Reply #4 on: January 29, 2009, 08:13:00 AM »
John,
Did you post your Ringmaster set up? I didn't see it here and am interested in using this size package for a new project in about the same size range as a Ringmaster.
Best,         Dennis
« Reply #5 on: January 29, 2009, 10:00:32 AM »
Dennis,
The motor is a HexTronik 42-40 but it is now called TURNIGY AerodriveXp.
https://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=2100&Product_Name=TR_42-40A_1050kv_35A_Brushless_Outrunner
MODEL: Turnigy -TR42-40
Max Efficiency: 30A
Max Load: 35A
Kv: 1050
Weight: 125gr
Pull: 800-1200gr
Porp Size: 10x6 or 9x5
Voltage 5-15v
No Load Curr: 3A
Size: 42x40mm 5mm shaft
The ESC is a HiModel FLY 40 AMP with BEC:
http://www.himodel.com/electric/HiModel_FLY_Seires_40A_Brushless_Speed_Controller_Type_FLY-40A_BEC.html
Type: FLY-40A BEC
· Weight: 36.5 g / 1.3 oz ( with connectors )
· Size: 70 x 25.7 x 8.7 mm / 2.7 x 1.0x 0.34 in
· Constant Current:40A
· Max Current: 50A (for ten seconds)
· FET: 18
· BEC: Yes
· PWM: 8 KHz
· Input: 2 to 3 cells Li-Po, or 6 to 10 Ni-MH/Ni-Cd
Note this is rated for 3 cells but I am using it for 4S and having no problems. It does get warm but not HOT.
The battery is a 20C 4S 2200 Li-poly (Hextronik) and or a Rhino 20C 4S 2150 mah:
https://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7364&Product_Name=Rhino_2150mAh_4S1P_20C_Lipoly_Pack
The timer is a Will Hubin FM-1
The prop is an APC 10-7
I get 46 oz static thrust from this setup and about 3 min flight time when the timer is cranked to full throttle.
I use this combination for sport flying as at age 76 my reactions are not that great. I do plan to try the "Beginner Pattern" at the 3rd annual Ringmaster Roundup in Houston, TX Memorial Day weekend. By then I should have a new (LIGHTER) ringmaster setup with governer mode ESC to fly.
As you can see I have gone CHEAP (Alan and others will not approve) but this is a workable combination for me right now. There is a park two blocks from my house and I can "sneak" over early in the morning and get in a few flights with no complaints so far. Ten to 12 inches of snow has me in building mode for now.
John Cralley
AMA 52183
Central Illinois
Alan Hahn
« Reply #6 on: January 29, 2009, 11:11:35 AM »
John,
I have no problem with cheap, sometimes it is a lot of fun to see what you can actually use.
The only problem is sometimes you can be burned (hopefully not literally! ~^)
« Reply #7 on: January 29, 2009, 06:16:24 PM »
John,
Alan,  So far no burns but I have managed to cremate an ESC (30 Amp) and to kill a battery (left it plugged in overnight -- dead, dead, dead)!! LOL
And cheers to all -- No more Rod Blago as Governor just ESCs with governor!!!!
« Last Edit: January 30, 2009, 07:15:57 AM by John Cralley »
John Cralley
AMA 52183
Central Illinois
Alan Hahn
« Reply #8 on: January 30, 2009, 06:58:06 AM »
One nice thing (IMHO) they included with last summer's CC Phoenix ESC software upgrade was a little beeper--when the throttle is left at 0%, the ESC gives a beep once every 15-20s to remind you that you left it hooked up to the battery. It is more useful than you might think, because after a flight, I'm always talking to others and it is really easy to forget to take out the battery. And as you note, the battery can be drained to zero and killed if it is left plugged in overnight.
Yes Blago is gone! #^
Online Dennis Toth
« Reply #9 on: January 30, 2009, 09:07:56 AM »
John,
Thanks for the information I find it interesting that there are lots of options in ECL. A couple additional questions, do you know the rpm the motor is running at and how much mah do you normally pull from the 2200mah pack for the 3min flight time? Also what line length are you using. I am starting a new project in the "35" size and am looking to use one of the lighter motors with a 2200mah pack to have a power package weight in the range of 12oz, that would compare to a "wet" FP35 with fuel and tank weight. Your setup is interesting I have looked at some battery 4s1p, 2200mah packs that weight in at around 8oz that are reasonably priced (I think the key to good battery performance is using a very high quality charger and pulling only about 80% out of the pack at 8-10C, seems even the cheap pack work with this) combine with a 4.4 oz motor and I in the ball park.
Best,           Dennis
« Reply #10 on: January 30, 2009, 10:14:15 AM »
Alan, That is more or less what I did. It was the last flight of the day. Had a little chat and rolled up my lines. Helpful buddies moved the plane and flight box over behind my car. Drove home and got lazy --- so I left the plane and flight box in the car overnight!! Bingo dead battery!!
Question, exactly which CC ESC are you and others using? I'm looking at the Phoenix 45 for my application. It should give me some margin for error since I seldom pull much over 30 Amps.
John Cralley
AMA 52183
Central Illinois
Alan Hahn
« Reply #11 on: January 30, 2009, 11:59:50 AM »
John,
I have been using the Phoenix 35--have 2 of them. Actually that is due to my "cheapness". It has often been on sale for quite reasonable prices ($60 as I recall) while the Phoenix 45 always has been over $100 (AFAIK). Even now with the Enobler, I only occasionally peak at 35A in the overhead maneuvers. Most normal flying (with a 4s battery) is at the 20A level.
« Reply #12 on: January 30, 2009, 12:32:19 PM »
Dennis,
I have not checked the "fuel" consumption in the field but I just made a static run of one minute and my charger put .614 Ah back in the battery so 1842 mah would be about 3 minutes worth. I did find that my ESC was getting hot and I had a thermal shutdown when I tried to do a full 3 minute run. It is time for a better ESC (a CC Phoenix 45 is on order  ;D)
The combination was pulling 29-30 Amps at 370 watts with a the rpm 9400 and the thrust around 40 oz. I had the Hubin FM-1 timer cranked back to minimum "throttle" which is supposed to be 70%. This was using the 4S Li-poly.
I presume that in the field the combination will unload some in flight so that it would possibly be pulling less out of the battery.
I have been using both 60' and 52' lines. The latter when conditions are windy. Being basically a sport flier, I am happy with this setup for now. It would be nice to know what the in flight specs are and an Eagle Tree system is HIGH on my wish list!! LOL
John Cralley
AMA 52183
Central Illinois
« Reply #13 on: February 14, 2009, 08:00:33 PM »
This is a bit off topic but Jim Swearingen and I went out to Hobby Hideaway (Central Illinois) and put on a couple of Feb. flights. The temperature was in the low thirties with a brisk west wind. We are going for flying at least once a month this year. There was some snow and Jim flew with a plane equipped with skis. I flew one of my electric Ringmasters with three inch foamy wheels.
I have a new Castle Creations 45 ESC and was using a 4S 2200 mah battery with a Hubin FM-1 timer. When I fired up the RM the motor spooled up slowly (the way it was setup to do) and just before I was ready to wave a launch it started to oscillate. That is it would drop RPM and then jump back up to speed then repeat this cycle. Since I was determined to fly I waved for a launch and flew a couple of laps in the oscillating mode. Then it kicked into full RPM and flew perfectly for the remainder of the flight.  The ESC was set for governor mode high and the timer for 70% throttle. I have no idea what was going on and really wish I had an Eagle Tree system monitoring my setup but that will have to wait for a birthday!!! I can only guess that something was getting "hot" and cooled off after a couple of laps in the cold air.
John Cralley
AMA 52183
Central Illinois
Offline Dean Pappas
« Reply #14 on: February 17, 2009, 10:33:03 AM »
Hello John,
Please tell us ALL of your ESC settings, especially the ones having to do with the governor.
Dean P.
Dean Pappas
Offline Mike Anderson
« Reply #15 on: February 17, 2009, 11:20:11 AM »
My first thought would be that the batteries were cold - resulting in a voltage drop that the ESC took as discharged batteries, so it went into cutoff - eventually the batteries warmed up  and the voltage held above the cutoff point .. maybe.
Mike A
Mike@   AMA 10086
Central Iowa
« Reply #16 on: February 17, 2009, 12:44:53 PM »
Mike,  You could be right though the battery was kept in the car until just before I flew. The temperature was around freezing so it could have cooled down a bit before the flight.
Dean,  I cannot give you the exact settings because I have now downloaded the new firmware for the CC ESC and programmed it in the new Control Line Governor mode. Saturday, when I made the flight, I had not yet been able to make the software work for the Castle Link. Since then I solved the configuration problem so I did the upgrade and reprogramming. To the best of my recollection the settings were all default except that I had it in Heli governor 2 (high) mode and timing #3 (low advanced). The brake was also set to disabled but I think that is automatic in governor mode (though that is not case in the new firmware control line mode).
Could the "low advanced timing" have been part of the problem? Maybe combined with the temperature of the battery?
John Cralley
AMA 52183
Central Illinois
Offline Dean Pappas
« Reply #17 on: February 17, 2009, 05:01:01 PM »
Hi John,
The other possibility is that the governor was set with too high of a gain, and was oscillating around the desired RPM.
Bench tests are a good idea ... do them at the same RPM as you expect in real life, but with a smaller prop to limit the current. Typically ground currents in governor mode are 130% to 140% of the in-flight current.
later,
Dean
Dean Pappas
