  • May 23, 2024, 05:21:17 PM
Author Topic: Ringmaster 593 Completed!  (Read 1571 times)
Offline Dave Rigotti
  • "Electric...The future of anytime stunt"
« on: May 14, 2020, 07:37:43 AM »
Finished up my PDK Ringmaster 593. I purchased just the wing kit from Pat and did the fuse/tail from "on hand" stock.
Fuse is a build up profile at 3/4" wide.  Lengthened the nose 1 1/4".
Cobra 3515/14 950kv
4S 2700 Zippy Compact lipo
Generic 40A ESC from eBay
Hubin timer
13x5.5 EP cut down to 12" APC prop
Monokote on wing and tail
Rustoleum on fuse , fin, and wing trim
.015 by 63' eye to eye lines
46 1/2 oz ready to fly with 3/4 oz tip weight.
I should have only lengthened the nose by 3/4" as I had to add 1 1/2oz tail weight to get to 16% CG.
It took 4 1 minute flights and 2 5 minute flights to get the Hubin timer values set so I could use the throttle compensation mode to give me 5.2 second lap times through out the flight.  Was very easy to do.  The 40A eBay ESC at $13 delivered was a gamble but looks like it will work out fine with this setup.  I think a very good setup for sport flying!
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline John Rist
Re: Ringmaster 593 Completed!
« Reply #1 on: May 14, 2020, 08:47:36 AM »
Very nice!  However I thought the big ringmaster was a 576 that could be built with or without flaps..  Is there a bigger one at 593?  My 576 has flaps.
« Reply #2 on: May 14, 2020, 09:54:04 AM »
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #3 on: May 14, 2020, 10:41:12 AM »
Looks great, but it is electric. D>K
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: May 14, 2020, 12:08:24 PM »
I have, and have flown at stunt contests, a ringmaster 1000
Offline John Rist
« Reply #5 on: May 14, 2020, 02:36:57 PM »
Who kits the 1000?
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: May 14, 2020, 03:18:07 PM »
Ringmaster envy?
Motorman 8)
Ha!
The 1000 was built from Pat Johnston plans by Larry Marx.
Pat King kits an 850 and the 2X, which is a whopping 1536 squares! Pics are of John Stiles
http://pdkllc.com/ringmaster-2x-260/
Online Crist Rigotti
« Reply #7 on: May 14, 2020, 09:04:28 PM »
Very nice Dave!  H^^ H^^ H^^
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: May 14, 2020, 09:30:58 PM »
Dave, sorry to wander on your thread. Beautiful model. A lot of us are passionate about big ringmasters!!
« Reply #9 on: May 15, 2020, 02:46:39 AM »
No problem Dane!
Thank You!
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #10 on: November 26, 2022, 01:15:34 PM »
The Lafayette Esquadrille has an OS-90 four stroke powered 2X sized Ringmaster (we call it the RingMonster). With that much wing area it floats on landing and it flies at 1/3 power with that .90 sized four stroke. We have 2.4 Ghz throttle control on the beast which makes it very managable. I do have to use my trailer to get it to the flying field however....84" one piece airplane, what were they thinking?
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Online Bob Hunt
« Reply #11 on: November 26, 2022, 05:44:37 PM »
That's just gorgeous, Dave!
Bob Hunt
« Reply #12 on: November 26, 2022, 08:11:41 PM »
Thank you Bob!  Very kind of you.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Brent Williams
« Reply #13 on: November 26, 2022, 10:17:33 PM »
Cool Ringmaster!
You could lose an ounce off the nose by switching to the Badass 2820/910kv.
The Badass 2820/910kv is rated for much more continuous power and is 30g lighter than the physically larger Cobra 3515.
https://innov8tivedesigns.com/badass-2820-910kv-brushless-motor.html
https://innov8tivedesigns.com/cobra-c-3515-14-brushless-motor-kv-950.html
« Last Edit: November 27, 2022, 01:52:00 AM by Brent Williams »
