  • June 23, 2025, 05:22:42 PM
Author Topic: Arming Switch  (Read 936 times)
Offline Matt Piatkowski
Arming Switch
« on: August 07, 2020, 03:47:55 PM »
Hello,
Is the arming switch required for the AMA regional contests? NATs?
If yes...where is it stated in writing?
M
Offline Crist Rigotti
Re: Arming Switch
« Reply #1 on: August 07, 2020, 06:23:52 PM »
Yes.
It's in the Competition Rule Book.
Offline pmackenzie
  • Pat MacKenzie
Re: Arming Switch
« Reply #2 on: August 07, 2020, 07:21:00 PM »
It does not have to be a switch, more common to use some sort of arming plug.
Note that it has to physically interrupt the battery power, not just disable the ESC
All aircraft that use electric propulsion shall have a positive arming device that, that when disarmed, mechanically prevents battery power from being applied to the motor. This may be (but is not limited to) a switch, the existing battery plug, or arming plug, but must be in series with the main power line(s) from the battery and mechanically disconnect the battery from the motor. Relying on the timer, timer start switch, flight programmer, or any other low-level logic signal for this function is specifically excluded. The model shall be restrained at all times while the system is armed, either by the pilot (including holding the handle before, during, or after an official flight), an assistant, or mechanical restraint device (e.g. stooge). The device must be disarmed after flight before the airplane is left unrestrained. Failing to restrain the model while still armed during an official flight attempt shall result in official flight with a score of 0. The system may be armed in the pits as long as it is restrained at all times.
https://www.modelaircraft.org/sites/default/files/CL%20Precision%20Aerobatics%202019-2020.pdf
MAAC 8177
