  • July 13, 2025, 05:56:03 AM
Author Topic: Rear bearing support mounts? Suggested by Norman Whittle.  (Read 1250 times)
« on: December 31, 2013, 04:39:36 PM »
It's great to dig for information. My shovel is getting bigger.  ;D
It's also great when you compare information from many sources. The results can be interesting to say the least!
I didn't dig this photo up, a fellow SH modeler sent me the link. Yes, true!  H^^
Obviously the photo shows a rear bearing support. First I heard of this?
Evidently someone belives it's necessary? Looks like Norman Whittle wrote the piece.
So, anyone using one?
Here's the link for anyone that may have interest, it's a good read!
http://www.castlecreations.com/products/control_line_stunt_setup.html
Charles
Offline John Cralley
Re: Rear bearing support mounts? Suggested by Norman Whittle.
« Reply #1 on: December 31, 2013, 06:38:11 PM »
On large front mount motors some say you need it some say you don't!  y1
 ;D S?P
John Cralley
AMA 52183
Central Illinois
Rick_Huff
« Reply #2 on: December 31, 2013, 06:59:50 PM »
Charles,
I ended up using one on a profile RD1.  The front mount I made wasn't stiff enough and some vibrations ensued.  The very simple rear bearing that I added completely solved the problem.
Rick
« Reply #3 on: December 31, 2013, 07:20:27 PM »
Charles,
Rick
Rick,
Thanks for the reply!
Where did you get the bearing and shaft plus the mount holder?  Everything has to be secure and stay in place?
Charles
Rick_Huff
« Reply #4 on: January 02, 2014, 01:03:28 PM »
Charles,
I got the bearing from McMaster Carr.  The motor is an E-Flite 15 and I bought an E-Flight 25 shaft to use in the E-Flight 15.  Its about 1/4" longer and just the right length for the bearing.  I made the bearing mount out of a small piece of basswood.  It's real simple, but it works.  I have a pic somewhere that I'll post when I find it.
Rick
Rick_Huff
« Reply #5 on: January 02, 2014, 01:10:36 PM »
Here's a pic of the rear bearing.  The motor was slid forward for the photo.
Rick
« Reply #6 on: January 02, 2014, 02:24:15 PM »
Rick,
What a guy! Thanks for the photos!
Nice work on your metal mount? Clever.
5mm on the bearing shaft thickness?
Obviously, the rear bearing has to be centered on the money.
Bearing/mount glued in place after the motor was in place?
Thanks again for that info and photos!!
Charles
Rick_Huff
« Reply #7 on: January 02, 2014, 02:41:11 PM »
I can't take credit for the front mount design.  I saw it on this forum a while back, can't remember who's idea it was.  Yes it's a 5mm shaft, and you're correct about gluing the rear mount in place with the motor mounted.
Rick
