I have changed the bearings in almost all of my motors at least once. They usually go well over 200 flights, regardless of the way the motor is mounted. Heavy props and spinners tend to wear bearings out faster.
You will notice excessive play at the prop (either/both fore and aft and side to side play) or noise...typically a kind of rattling sound and vibration. Bearings are easy to change (note: e-flite glues in the bearings with what appears to be cyanoacrylate...a gentle tap is enough to free them). I use a punch made of 1/8" music wire to catch the lip of the bearing, moving it around the circumference of the bearing until it pops out.
Bearings are available from a number of sources. BOCA bearings in Florida is fast and reliable. RCBearings.com have a good inventory as well, but I have not been impressed with the quality of their bearings. Innov8tiveDesigns.com (suppliers of scorpion and cobra motors) stock bearings for all the motors they sell at very reasonable prices.
Hope this helps.
Bob
