  • July 07, 2025, 04:33:16 PM
Author Topic: Question on chargers...  (Read 780 times)
Offline jim gilmore
« on: June 24, 2010, 05:00:20 AM »
I know most chargers run of car batteries,but I was looking at an ad for one and i think it was using a laptop power supply for power. Does that seem normal ?
Offline Bud Morrison
Re: Question on chargers...
« Reply #1 on: July 26, 2010, 07:36:46 AM »
Unless you have one big laptop power supply there will not be enough amperage to charge most cells unless you are charging small packs.
You can however use a Desktop power supply.
http://web2.murraystate.edu/andy.batts/ps/powersupply.htm
Offline Mike Anderson
« Reply #2 on: July 26, 2010, 08:01:36 AM »
Depends on what charger you have and what you are charging with it -- if your laptop supply is able to supply 5 amps at 12 v., you can use any of the small "50 Watt" chargers and charge a 3-cell at almost 5 amps, a 4-cell at about 3.5 amps, etc.  (Most of the laptop supplies that I have seen lately are at least 5 amps and many have a selectable voltage output that usually goes from 11 volts up to 18 volts).
If you have a charger with more than 50 Watt capabilities, you will need a proportionally larger, more powerful supply.  If you are not into modifying electronic devices, your can find 12 volt, 10 amp (and larger) supplies from various suppliers for reasonable prices.
Mike@   AMA 10086
Central Iowa
