  • July 08, 2025, 09:07:50 PM
Author Topic: Question for Dennis Adamisin  (Read 714 times)
Offline jim gilmore
« on: September 15, 2010, 10:56:27 AM »
Ok, As I said my memory is faulty.
Is Brodaks 1/2A electric comprabile to the system you were using in the 1/2A pathfinder you built.
http://stunthanger.com/smf/index.php?topic=14264.0
If not what all is different ?
Re: Question for Dennis Adamisin
« Reply #1 on: September 15, 2010, 05:22:38 PM »
Hi Jim,
The 1/2a Patfinder uses a Arrowind 2210 motor, 18A ESC, Hubin FM-0c timer and 3Sx1300 pack.  Turns a 7x5 pusher with the power of a good 09-15.
The Baby Clown uses the Arrowind 2205 motor, 12A ESC, Hubin FM-0e timer and 2Sx850 pack.  TUrns a 6x5.5 prop, power of  a Medalian 049.
There is also an ultra-light 020 system using the 1806 motor, 12A ESC, Hubin FM-0c & 2Sx450 pack.  Intent is to fly a 1/2A sized bird with a 6x4 prop indoors on short lines.  I have one of these set-up in a Swordsman 18; 4.25 oz RTF!
Forgot to mention this, the link you had in your message was to a project my nephew did with is son.  A TERRIFIC story...
Offline Archie Adamisin
« Reply #2 on: September 15, 2010, 07:36:01 PM »
You may even try this thread.  http://stunthanger.com/smf/index.php?topic=15037.0
It worked great until the stab broke on the bottom of an outside loop.   HB~> HB~>  Stupid punk Balsa.  I knew better.  Wing is repairable so I hope to convert it to a combat Streak with full fuse.
The light outruners will equate to a lower RTF weight and still make the power.  Really depends on what type of performance you want.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
