  • July 08, 2025, 03:07:01 AM
Author Topic: QUESTION FOR DEAN- BATTERY CHOICE FOR SV-11  (Read 772 times)
Offline Frank Imbriaco
« on: April 08, 2011, 05:58:41 AM »
Hi Dean,
I'm woking on my Brodak SV-11 ARC. ( 60 1/2", 49 1/2", 676sq. , completed weight target 65 ounces) .
I've  already purchased an E-Flight Power 25 -870KV , CC Ice Lite 50 ESC, and APC 12x6, 13x 4.5 Pusher props.
What size  battery- Capacity and C  rating  , 4S or 5S , do you recommend?
 Any other advice would be much appreciated !
Frank :-\
Offline Russell Bond
  • Bandolero
Re: QUESTION FOR DEAN- BATTERY CHOICE FOR SV-11
« Reply #1 on: April 08, 2011, 06:28:00 AM »
I know I'm not Dean, but..............
I have a 690 square inch, 70oz plane with a 930kv motor using a 13x4.5 ePusher set at 9500rpm for a 5.5 secs/lap on 68.5' lines (total) and I use a 4s battery that is 3300mah. I use about 2400mah per flight. (72% used.)
A 4s would be perfect for your plane.
(20 to 25 C-rating would be the one to use.)
Hobbyking sell a Turnigy Nano-Tech 3300, 25c, 4s for about $38 and it only weighs 11.9oz.)
Bandolero
Offline JohnPrator
« Reply #2 on: April 08, 2011, 07:11:35 AM »
Frank,
I'm not Dean either and have no where near the experience or knowledge but I am building an SV-11 at the moment as well. My motor is/will be the Scorpion 3026-890 swinging a 12 x 6 EP prop, I'll probably give a cut down 13 x 6 a try too. After speaking with Bob Branch quite a bit I decided to use the GensAce 4S 3800 battery in mine. I like the Gens batteries as they are inexpensive, powerful, well built and ship free from HobbyPartz right here in the U.S. I figured out a nice way to install mine in the SV and the 3800 fits great, hope to have some photos up soon.
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, signed a blank check made payable to "The United States of America", for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it. -- Author Unknown
