Electric Stunt => Gettin all AMP'ed up! => Topic started by: Larry Wong on July 11, 2008, 05:02:23 PM
Any body know what is the best way to use a pusher prop?
Which wires do I exchange? (on motor)
do I have to change ESC to reverse?
Larry,
Swap any two wires between the ESC and a brushless outrunner motor and that will reverse the rotation. I have no experience with other motors.
Larry,
John is right, you don't have to change anything in the ESC--just switch any 2 of the three wires between the ESC an brushless motor.
John is correct. On a brush less motor it makes no difference which two that are switched.
As for the ESC you don't have to make any change at all.
The propeller itself needs to be mounted backwards on the motor (writing towards the motor).
Robert
Robert
I'm using a 12x6 EP Pusher prop. do I still have to turn prop around!!!!!!
Basically the part of the prop that has the numbers on it should face in the forward direction.
Remember that some people run "pusher" props as "tractor" props with motors that rotate CW (as viewed from front of plane) to counteract torque on takeoff.
The more I try to explain it, the more confused I'm getting! HB~>
Yep I though so tractor ( John Deer) turn conter clock wise. Pusher turns clock wise to (advance time) n~ n~ y1 y1
LL~ LL~ LL~ LL~ LL~ LL~ LL~
Result today with pusher prop, was it works great kept the plane out on lines in the whole pattern even overheads, but my plane never had any trouble with staying out on over heads , so it was hard to till if it work better or not. n~
How about a look at this thing!
Robert
Uhm, ok now I've thought too much about this and i'm confused.
Larry,which is it a pusher prop in front ,running the motor in reverse so its a Tractor again or is it reallt pusher?
Ok the prop I used is a clock wise foreward tractor, and the normal forward prop turnes conter clock wise.( simple) <= <= <= n~ n~ HB~> HB~> LL~ LL~ n~ n~
Larry,
Since in PA we fly just about as many maneuvers outside as inside, it isn't obvious there is any advantage of the pusher prop turning clockwise (from the front of plane) as a normal tractor prop turning counter-clockwise. The major advantage is at takeoff or low airspeeds where the torque tends to turn the plane in towards you. Speed and Carrier guys like the pusher for this reason--but they are always flying upright --at least on purpose!
Alan on the C/C esc new firmware can I lower the RPM on my motor for flight speed? if so how? my timer is as low as I can go.
I am guessing that in RPM mode, you can put in any value you want---consistent with the battery voltage and motor kV of course. What rpm are you currently running?
Larry,
Hi Alan,
I hate to be contrary, but nothing could be further from the truth! Inverted and upright have almost nothing to do with it ... it isn't a rolling issue, it's a yawing thing. The spiral airflow gets worse at low airspeeds, and straightens out at higher airspeeds. Soooooo every time the nose is pulled up and the plane looses a bit of airspeed, the spiral airflow angles get worse. The spiral airflow pushes the tail right and the nose left. That means that with a normal prop, every time the plane slows, it yaws inboard. Put a pusher prop on the plane, reverse the rotation, and now every time you slow, the plane yaws outward. It's amazing how the "above 45" line tension improves especially as compared with the level lap line tension.
This really is an advantage for E-Stunt.
Dean
P.S. Happy Bastille Day, Y'all! Go overthrow something!
Dean,
I guess you are right! I was tending to think of the gyro precession in a sharp corner where insides and outsides behave oppositely---the reason for the Rabe Rudder.
But the propwash, I guess, is also the reason for the little bit of right thrust that we sometimes build into the motor.
The biggest problem with pushers is prop availability, but as I replied to someone else in another thread, APC seems to be producing more pusher E props too. Need to take a look to see if they have a 12-6 version.
Hi Alan,
Yes, there is an APC 12-6 E pusher #^
Dean
