  • July 28, 2025, 12:06:09 PM
Author Topic: Purpose of EMax motor copper ring?  (Read 3851 times)
Offline kiwibrit
« on: March 01, 2015, 05:07:46 PM »
I am embarrassed to say I found out that my EMax BL2820/07 motor had a phosphor bronze or copper ring (like the one in the picture) when I came to reassembly -  I had not noticed it on strip down. OD 6mm, ID 5mm, Length 1mm.  It slips neatly over the drive shaft. I followed advice from an experienced electric F2b flier, and installed it on the shaft between the Eclip and the rear bearing.  Do you guys think this is correct?  It appears to have no internal purpose.
Offline William DeMauro
Re: Purpose of EMax motor copper ring?
« Reply #1 on: March 01, 2015, 06:39:17 PM »
Just looked at my NIB 2820/07 and you put your ring in the right place.
AMA 98010
Offline kiwibrit
« Reply #2 on: March 02, 2015, 02:28:17 AM »
Many thanks.
Offline Target
  • C/L Addict
« Reply #3 on: March 19, 2015, 10:13:22 PM »
How is the Emax 2820/07 performance?
The specs look pretty good....
But so does the Power 15 3D. Although its impossible to know if the numbers are accurate.
http://www.headsuphobby.com/Firepower-15-3D-800kv-Outrunner-Brushless-Motor-E-717.htm
Chris
Chris
AMA 5956
Offline kiwibrit
« Reply #4 on: March 20, 2015, 02:33:03 AM »
From my experience, the EMax BL2820/07 is a cheap and cheerful equivalent of a 40 engine. I run mine with an APC 11x5.5 prop and 4S batteries. Spares are also cheap and readily available.
Offline Target
  • C/L Addict
« Reply #5 on: March 20, 2015, 08:29:13 AM »
Thanks for that.
What flight times are you getting and on what capacity packs?
Thanks!
Target
Chris
AMA 5956
Offline kiwibrit
« Reply #6 on: March 20, 2015, 01:51:53 PM »
I was using 2200 mAH packs for 5 minutes flights with a Brodak Smoothie - a little on the low side perhaps, but then I don't yet fly square manoeuvres.
Offline Target
  • C/L Addict
« Reply #7 on: March 20, 2015, 10:52:15 PM »
So then would you say you are likely pulling about 20A?
Chris
Chris
AMA 5956
Offline kiwibrit
« Reply #8 on: March 21, 2015, 07:27:21 AM »
I'm guessing at 20 - 25, but don't have measurements/logged data. I use a 40A ESC with this set up, and it seems to be fine.
Offline Target
  • C/L Addict
« Reply #9 on: March 21, 2015, 09:52:12 PM »
Thanks for the reply.
I have a almost done Banshee with an OS 40FP on it, but truth be told, I really can't wait to try out an e-power C/L plane.
I haven't flown C/L for @20 years, but am quite active in RC sailplanes (F3F/F3B/F3J) and DLG's... And dabbled in e power heavily about 10 years back.
I'm excited to get back into some C/L for a change of pace. So I'm trying to absorb as much E-C/L info as possible...
Chris
Chris
AMA 5956
Offline Keith Renecle
« Reply #10 on: March 22, 2015, 10:40:57 PM »
Hi Chris,
I've used a lot of the E-Max/Arrowind 2820 motors and they work really well for a .40 size engine replacement. The E-Flight Power 15 is about the same but a better quality motor. Most likely the Cobra 2820/12 is about the best deal right now, so you have a lot of choices. The battery size also has to do with what is readily available and popular for the R/C models, so the 4 cell 2200 mAh 25C is a good choice for a 5 minute motor run. You don't need a higher C rating than 25 for C/L stunt.........you just add weight. However the battery size all depends on the weight of the model. I've added a chart of one of my old test models called the Eze 40 and it weighed 1100 grams or 38.8 oz. It flew the pattern easily on that battery for even a 5 min 30 flight with the APC 11 x 5.5 E prop. Most of the profile models I've tested for this size weigh from 1100 grams to 1300 grams (46 oz). At 46 oz the 2200 battery is pushing it's limit for a 5:30 flight, so the trick here is to keep the weight down. Something like a Banshee can be built light if you get rid of the heavy nose with those engine bearers. Electric motor's do not vibrate like the older engines............especially the Fox 35, so it's not necessary to make such a solid nose. It sure needs to be rigid, but does not need to be anywhere near as heavy.
You can see from the chart below taken from my Eagle Tree data recorder just how the current goes up and down during the flight. The average for that flight was around 18 amps, so your guess of 20A is pretty good! There are many threads on this site that show how to calculate everything and that is what makes e-power so nice. You don't need a dyno to work out power as everything is easily measureable. The other trick is to just keep asking questions on this forum and many will jump in and help. Have fun!
Keith R
Keith R
Offline Target
  • C/L Addict
« Reply #11 on: March 23, 2015, 06:30:23 AM »
Thanks a lot for the detailed information, Keith!
The banshee was started with IC in mind, so its already got the beefy front end.
If I E-power the Banshee, I will build another separate fuse, maybe a whole other plane from the plans.
The wood was a bit die-crunched on my Banshee kit anyway. My own stacked ribs will be better....
Thanks again for the thorough reply, its what I was looking for.
Kind Regards,
Chris
Chris
AMA 5956
« Reply #12 on: March 23, 2015, 10:13:59 PM »
My pleasure Chris. If you need some ideas on a simple electric nose construction, I have the plan of my Eze-Pro profile stunter that has been built many times. I also have some photo's to help, so send me a PM and I'll get your e-mail to send you stuff if you like.
Keith R
Keith R
Offline Target
  • C/L Addict
« Reply #13 on: March 23, 2015, 10:41:24 PM »
PM sent, thank you. H^^
R,
Chris
Chris
AMA 5956
