  • July 09, 2025, 10:25:57 AM
Author Topic: Props  (Read 762 times)
Offline paul winter
Props
« on: October 06, 2012, 01:22:49 PM »
So here i am hooked on electric
been flying my new model and trying out different props ....12x6 tractor ,,,,12x6 pusher
im asking the experts on prop info ,,how does a pusher to a tractor help as the electric runs smooth unlike a four stroke
i have had 10 flights on each and bar the top of the square 8 not a lot seems to be different between them
am i missing something or is my model not trimmed right ????
paul
Online Bob Hudak
Re: Props
« Reply #1 on: October 06, 2012, 03:16:50 PM »
Paul,
 When I made the switch to a pusher prop  one of the biggest things I noticed was the plane didn't go light on the lines in the top of the vertical 8 and hourglass.
 Bob
350838
Offline James Strickland
Re: Props
« Reply #2 on: October 07, 2012, 12:57:52 AM »
Or anyplace else in the pattern for that matter,  "TOTAL" line tension  everywhere, that is the advantage.----James
Re: Props
« Reply #3 on: October 07, 2012, 05:57:54 AM »
You tell me it even helps the maneuvers that had good tension to begin with in the pattern?   I mean  inside loops with the  wind blowing try to pull me off balance.
