  • June 16, 2025, 01:44:31 AM
Author Topic: Overheating of electronics - symptoms?  (Read 2842 times)
« on: July 28, 2023, 06:13:00 AM »
Guys,
A quick question on cooling the electronics package. The new ship has everything nicely fit into the available space in the nose (Barnstomer). I am working up to full flights with the motor (BadAss 2320 720), 5S-1800mah HobbyStar pack, 10x6.5 APCE P prop, rpm 9700, static amps ~19. One of the things I always get considering with on a new ship is if there is enough cooling. This ship has the enclosed shaped to the spinner nose (like on the box picture), it looks very cool but most of the cooling is through the spinner into the motor and back through the fuse. This has worked well for me in the past on other ships (my Stuka) but there was more of and open cowl. For the short test flights (30 sec) you can grab everything as it is only warmish. I plan to increase the flight times slowly but don't know how long of a flight time does it take to get to peak temperature.
I was wondering what would be the signs to watch out for if the ESC/timer were getting too hot?
Best,    DennisT
Re: Overheating of electronics - symptoms?
« Reply #1 on: July 28, 2023, 07:02:59 AM »
What do you have in the way of air exits?  You have to get an air *flow* over the esc and to some extent the timer.  It doesn't have to be huge, just constantly moving towards the exits.  But, for air to get out, it must also get in and the spinner is not enough for that.  Also, the exits need to have a suction effect so that the airspeed is drawing air in the front and pulling it out the rear.
Get an infrared temperature gun.  They are not very expensive.  If things get too hot, the damage is already done.  Measuring it after the fact only confirms that you need to replace it.  You are doing the right thing sneaking up on it.  How hot is too hot?  If you can't hold it, it is too hot.
There should be a high temperature cut off in the ESC but that may or may not be the high for the motor and timer.  I would worry most about the motor.  Not sure which ESC you are using.
I know it is somewhere, but I can't find it.  A Picture!  Can you post one of the top and bottom with and without hatches?  Who knows, someone may have crossed this bridge already and has the solution.
« Reply #2 on: July 28, 2023, 07:16:15 AM »
I don't think there are too many warning signs, maybe think about drilling some holes.
MM 8)
« Reply #3 on: July 28, 2023, 07:28:22 AM »
The ESC is a Castle Creation Talon35. I am well below the amp rating on this ESC and should be OK. The BadAss motors can take over 300F (from their website). The battery is a 120C rating way more then needed but is the right size, weight and capacity. I think I need to open up the bulkhead for the wing mount to allow full flow through the fuse. There is an outlet on the bottom but having the flow also through the fuse should keep the flow going better.
Best,   DennisT.
Offline Kermit Payne
« Reply #4 on: July 28, 2023, 07:47:22 AM »
Dennis,
Based on what I have read and by experience, a symptom of overheating is reduced power.  Your ESC likely has a high temperature protection feature that will reduce power to the motor.  This will (theoretically) protect the electronic components from being damaged by excessive heat.  If the temp gets too high, expect to see a motor slow-down until the timer times out.  Once on the ground, take off the hatch to provide as much cooling as possible.  If you have asbestos fingers, CAREFULLY touch the ESC, motor and timer.  They likely will be too hot to the touch and will remain so for what seems like an eternity --- probably no more that 5 - 10 minutes, but we modelers are an impatient, restless sort.  If you are lucky, the thermal protection features did their job and the airplane will live to fly another day (after appropriate cooling modifications!)
Kermit
« Reply #5 on: July 29, 2023, 09:16:49 PM »
If you can open it up fairly quickly after a flight then get it open and rummage around in there, paying attention to how warm things feel.  Obviously the motor can stand to get very hot so you probably don't want to lay your finger on that without great care.  The batteries should feel barely warm to the touch, and the ESC should be well under the temperature where you can hold onto it comfortably.
(Note that I'm a industry trained analog circuit designer.  Part of the industry (not university) training is that the temperature where you say "ouch" and want to pull your finger away from a surface is about 50 degrees C -- and for a system operating in room-temperature air, 50 degrees C on the heat sink usually means that you'll be fine up 55 degrees C ambient.  So if your ESC has a bare heat sink, and you can touch it without wanting to pull away, then you're fine).
(Speaking of 300F -- that'll make your finger sizzle, but not get a shiny patch.  Just in case you didn't listen about the "be careful of the motor" part.)
If the various important bits of the system are visible from the air intakes or exhausts, consider getting a cheap IR point & shoot thermometer from Horror Fright Tools.  As soon as you land, measure the temperatures of the bits, and make sure they're within comfortable ranges.
