  • July 29, 2025, 08:36:11 AM
Author Topic: prop mounting ??  (Read 839 times)
Offline jim gilmore
prop mounting ??
« on: June 25, 2008, 01:47:37 PM »
For those that have used or tried the gobrushless motors. What yhe best method ? i've gotten a prop adapter but it seems much larger yhan the hole in the props. shoud I drill the out ?
Offline John Cralley
Re: prop mounting ??
« Reply #1 on: June 25, 2008, 02:19:31 PM »
Jim,
It would be best if you used a regular prop ream. They come in stepped intervals for reaming a prop to the correct size. It is difficult to accurately drill a prop because the drill will tend to "walk" off center. It can be done (I've done it) but reaming the hole would be better.
John Cralley
John Cralley
AMA 52183
Central Illinois
Alan Hahn
« Reply #2 on: June 25, 2008, 07:10:19 PM »
Jim,
I've used APC electric props, and I think they are larger than the gobrushless prop shaft (but need to look). You need to use the little plastic prop adapters ACP provides with the electric props. The "precision"  hole is the back hole, whereas the through hole is not always centered. I always ream out the through hole so that if it is offset, it doesn't interfere with the centering provided by the adapter.
