Electric Stunt => Gettin all AMP'ed up! => Topic started by: Paul Allen on February 07, 2010, 01:15:01 PM
Another question!
I found a prop data sheet for a Scorpion 3020-890 motor
it lists prop size, amps, watts, prop RPM, etc, my question
is the figures listed for a prop, does that mean the motor
is most efficient at that amp draw and RPM,I remember
reading in a post that a motor running at 25 amps is
giving its best performance where another motor may
give its best at 35 amps? Does that cross reference to
the prop charts?
Paul Allen
Paul,
If I understand your question, the answer is no.
The Scorpion prop tables are the values for that prop, motor, and voltage if you would be running at wide open throttle (WOT)----on the bench.
As such they are useful, because they can give you an idea of the maximum amps (under load) you would pull at that voltage during a flight. Since we typically fly at less than WOT, we would even pull less amps.
When I was putting together my electric Nobler setup, I was wondering what kind of motor I would need to fly it. I knew that I launched my glow Nobler at less than 10k rpm with an 11-5 prop, and I had the 3s batteries I was using in my electric Super Clown, so I was able to pick out a motor (3020-12 I recall) that would reach that rpm with my 3s pack. Also I wanted to know if my Phoenix 35 ESC was large enough (it was/is).
