  • June 15, 2025, 04:47:40 AM
Author Topic: Prop adapter  (Read 1796 times)
Offline Alan Resinger
Prop adapter
« on: June 18, 2011, 09:54:14 AM »
I'm just starting to build my first e-stunter and want to use a Precision Aero 1.75" spinner.  The motor is an e-flite.   The 5mm adapter that comes with the motor has a 1/4 28 threaded shaft that is about 3/8 to 1/2 inch too short to be able to mount an APC e-prop and the AP spinner.  Anyone know of a adapter that would be long enough.  I'm going with the Randy's spinner as I need the weight and like the shape better than an e-flite spinner.
Offline Allan Perret
  • Proverbs
Re: Prop adapter
« Reply #1 on: June 18, 2011, 10:07:09 AM »
How long is the 5mm adapter you have, or how long would it have to be to work ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Prop adapter
« Reply #2 on: June 18, 2011, 12:50:49 PM »
The threaded portion of the prop adapter is only about 3/4" long.  The motor includes the adapter.  It has a small cone shaped nut to secure the prop.  As I said the unit needs to be 3/8" to 1/2" longer.  If you go to Horizon Hobby and look up E-flite motors you can see the assembly.
  • Proverbs
Re: Prop adapter
« Reply #3 on: June 18, 2011, 03:37:26 PM »
Bought an AXI motor recently and also an optional prop mount # PH5 that had a longer spinner screw.  I was thinking that might work for you.   But the Aero spinners use the 1/4-28 spinner screw, so that wont work. I dont know of any electric prop mounts that will work with an Aero Spinner.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline ptg
Re: Prop adapter
« Reply #4 on: June 18, 2011, 04:05:38 PM »
Here is a varied selection.  Good luck!  <http://www.radicalrc.com/category/Prop-Adapters-Collet-&-Etc.-36/rec/48>
PT Granderson
Re: Prop adapter
« Reply #5 on: June 18, 2011, 06:50:25 PM »
Alan, you may look at tru turn , they are producing adapters for electrics now as well, I dont KNOW they have anything, but its worth a shot
http://www.truturn.com/af_electricmotors.htm
Offline Crist Rigotti
Re: Prop adapter
« Reply #6 on: June 18, 2011, 08:07:34 PM »
They will also slot the spinner for a pusher prop.  Aren't Randy's spinners are slotted for tractor props?
Offline Ward Van Duzer
Re: Prop adapter
« Reply #7 on: June 19, 2011, 10:40:22 AM »
Help from Kieth Varley under Spinners for pusher props.
http://www.maxxprod.com/
Spinners and DOZENS of adaptors!
W.
