  • June 20, 2025, 02:20:57 AM
Author Topic: Programming a Phoenix 45 ESC  (Read 1052 times)
Offline Ron Hook
« on: January 28, 2011, 07:09:04 PM »
Well gang, I am a newbie to electric control line and would really appreciate help with programming a Phoenix 45 ESC. I will be flying the following:
AXi 2826/10 920 KV
Castle Phoenix 45 ESC
Hubin FM-9 Timer
FlightPower EVO Lite V2  4s  4270 mAh  14.8 V
After much reading, I set the following parameters for the ESC. I would like comments, advice, suggestions, etc. before attempting to run this motor with these settings. I would use a motor stand for testing before installing in the plane.
Throttle Settings
vehicle type - control line
throttle type - governor mode
governor gain - 35
initial sppol up rate - 6
high speed change rate - 6
battery type - LiPo
# of cells - 4
battery voltage - 14.80
gear ratio - 1:1
motor kv - 920
# of poles - 14
The three head speeds are left at optional because I did not know what to put here.
Brake Settings
strength - 100% (hard)
delay - .6 sec (delayed) (default)
ramp - very fast
Cutoff Settings
cutoff voltage - auto LiPo (default)
volts/cell - 3.0 volts/cell (default)
limiting - normal (default)
type - soft cutoff
Motor Settings
start power - medium (59) default
timing - Custom (4)
direction - forward (default) Intend to use pusher prop and will change wires at motor for reverse.
PWM rate - 8 Khz
Other Settings
power on beep - enabled
Software Settings
device name - Phoenix-35/45 (F310)
current firmware - V 3.26 (beta)
I want to thank everybody in advance for any help that comes my way. Anxious to get flying. Weather where I live (25 miles west of Phoenix) was 75 today and sunny.  Another boring week of the same is forecast for next week.
Ron Hook
Goodyear, AZ
Ron Hook
Goodyear, AZ
Offline Rudy Taube
  • Ret Flyboy
Re: Programming a Phoenix 45 ESC
« Reply #1 on: January 28, 2011, 08:52:46 PM »
HI Ron,
I am very glad you are getting your E-CLPA ready for flight. You have all the right E parts selected and your beautiful plane will have plenty of power. :-)
BRAKE
I have not used the CC CL version yet so I don't know if you have a choice in the BRAKE setting? If you do, you may want to set it for a soft brake, so that it does not "abruptly" stop the motor. There is no need to stress the system with this violent sudden stop. My guess is that since Bob/Dean worked with CC on the CL version that they have the correct setting as standard.
SPOOL UP SPEED
The only other setting that is up to the pilots preference is the spool up time. I set mine for a very slow spool up because I like the realistic TO on pavement, but on grass I have to make sure I let it spool up while being held until it reaches a high enough RPM to TO safely in the grass "of the day". This slow spool up setting makes it much easier to fly the plane slowly off the ground and slowly climb to the 5' altitude over the complete 1st lap. ..... Some guys want it a fast spool up to duplicate what they are used to with FULL POWER TOs like their wet systems gave them. ..... Like all the settings, this can  be changed to find the one that suits your style. :-)
YOUR SETTINGS
It looks like all your settings are OK. I'm sure others will comment here and may have some suggestions for changes. There is a great amount of experience on this forum and I'm sure you will end up with the optimal settings in the next few hours. ;-)
Thank you for making such a complete listing of settings. Once it gets a complete peer review here it will be very helpful to everyone to use as a template for their setups.
PS: Other than the SW champs, and the CL contest in Feb., when is your next CLPA contest? I would like to come over and fly with you this spring if you have a contest then.
Warm Regards,  H^^
Your WNY friend
Rudy
AMA 1667
Offline Ron Hook
« Reply #2 on: January 28, 2011, 10:07:11 PM »
Hi Rudy,
Good to communicate with you again. I am glad to hear that I am on the right track with this setup. Look forward to others help also.
Our Southwick contest that is usually held in February has gone to the "dogs". Literally, a group paid the local city a bundle of money to have a a dog show at our field pushing us out of the way. Money does talk! Our next local contest will not be until fall again.
Ron
Ron Hook
Goodyear, AZ
Offline John Hammonds
« Reply #3 on: January 31, 2011, 04:01:31 PM »
Hi Ron,
 I can't comment on features such as  Governor Gain, Head Speed change rate etc because as Rudy says they are really personal preference and you will arrive at your ideal settings over a number of flights.
I usually set the Brake Ramp at Slow <-> Medium, just because as already said "No need to stress the system". Not sure if it is also the case in the US but in the UK the prop must be stationary on landing so I set "Brake Strength to "100% (Hard)" which seems to do the job for me at least. For the same reason I set "Initial Spool-Up Rate to "4" (Any less and it takes an age to haul itself off the line if the grass is a bit long).  For "Cutoffs" I use "Auto Li-Po" and 3.2 Volts/Cell. 3.0 is probably fine but you are pretty well flat before then and probably want to land anyway. Against certain advice I set "Current Limiting" to "Very Sensitive" and have never had a motor cut during manoeuvres yet.
The 3 head speeds are not necessary and can be left blank if you use "Governor High or Low" but should be used if you select "Set RPM". I can't find any details of "Set RPM" in the user guide but I "Think" it works as follows.....
Set RPM gives you 3 speeds depending on your Throttle position, Speed 1 is Throttle % from 1->49, Speed 2 is 50%->99% and Speed 3 is 100% If you have a timer which "Ramps" up to compensate for voltage drop you can set it to run at head speed 1 one until it begins to compensate for voltage drop then switch to speed 2  and finally speed 3, certainly this is how it seems to work with my jmp timer. A few more revs for the 2nd part of the pattern was always reassuring as well.
My description of Set RPM may well be complete rubbish and I'm sure someone will jump in if this is the case.
TTFN
John.
BMFA 165249
« Reply #4 on: January 31, 2011, 04:49:48 PM »
just a note - your governor gain is set WAY to high - being that high you will get surges in power with the slightest change from level flight - not something you want really
as mentioned above -
1 make the changes to the "brake"
2  set your current limiting to very sensitive - this will shut the system down if you have a prop strike on takeoff or similar (kinda important)
other than that is looks pretty good - what is the model and weight?
« Last Edit: February 01, 2011, 02:11:21 PM by Wynn Robins »
Offline Ron Hook
« Reply #5 on: February 01, 2011, 03:23:48 PM »
Thanks John and Wynn for your very useful information. I will make some changes in the ESC.
Wanted to fly tomorrow but Arizona decided to turn cold and windy for the next couple of days.
Ron Hook
Ron Hook
Goodyear, AZ
Offline WhittleN
« Reply #6 on: February 01, 2011, 07:02:01 PM »
Ron
Your initial settings look very good.  I know some on the forum would suggest other settings.  I would suggest two things, 1 use the settings in your opening post and 2, look at the "cookbook" in the sticky paste and compare your settings.  I didn't just pullthese settings out of thin air, they are tested and I consulted several knowledgeable folks before I publish them.
Hope the weather turns nice and you get to fly soon.
Norm Whittle
Offline Ron Hook
« Reply #7 on: February 01, 2011, 11:16:12 PM »
Norm,
Thanks for the advice. In fact, I did use your "cookbook" for my original settings. By far, it has been the most helpful article out there for people not quite sure where to begin. Thanks for all the great information. I have downloaded it and printed it our for my files.
Ron Hook
Ron Hook
Goodyear, AZ
« Reply #8 on: February 02, 2011, 04:57:32 PM »
Ron,
The settings look good to start with. You might want to consider reducing the brake delay to .2 and keep it at the fast ramp. I have used these settings and it is not a problem. This is more important when the wind comes up. If the prop windmills it will be more difficult to control the landing. Before CC enabled the brake for CL I had a ship come into wind and the windmilling prop stopped the ship 2ft off the ground and it just dropped, lucky I was over grass and it just bent the gear. With the brake no problems at all, but the quicker you get the prop stopped the better.
Best,                DennisT
