  • July 31, 2025, 11:46:01 AM
Author Topic: Problems with Castle Link  (Read 1094 times)
Offline andreas johansson
  • SWE-56998
« on: May 29, 2009, 01:45:09 PM »
Hi all!
I have a problem with Castle Link and I would like to hear if someone else have the same problem OR a solution to it.
The problem is:
I have setup the ESC to use set-rpm and when I choose "no gearing / direct drive" in the gearing/kv/poles window I get a error message saying "Input string was not in a correct format" and a lot of other .NET related information. If I set the gearing (to 1:1) with one of the other two options it works fine. If I click cancel in the error message window the program closes. If I click resume the program continues to run but the setting above is not stored in the ESC. In all other ways the program works.
I have tested this on 6 different computers with either XP, Vista or Windows 7 and I get the same error on all of them. English or Swedish operating system doesnt matter.
I have version 3.13 of Castle link and the latest firmware in the ESC.
Andreas
Nobler-O-Maniac
SWE 56998
Re: Problems with Castle Link
« Reply #1 on: May 29, 2009, 02:04:51 PM »
Hmmm, as I recall the only thing you can write-in on that screen is the motor kV, everything else is a drop-down menu selection...
* I set-up on a VISTA laptop.  I downloaded the software, then "ran as administrator" to insall it.  That was the only way I could get a clean installation.
* You might try dropping back on the Firmware selection from version 2.11 to the prior issue - I think it was version 2.0
* On the FIRST screen you might try the "Upload Default Settings" (lower RH side of screen) to get everything settled in, THEN start programming to suit...
  • SWE-56998
« Reply #2 on: May 29, 2009, 02:27:00 PM »
Hi
Thanks for your answer, unfortunately I have tried all your suggestions with no luck.
Andreas
Nobler-O-Maniac
SWE 56998
Offline John Cralley
« Reply #3 on: May 29, 2009, 04:07:28 PM »
Andreas,
As far as I recall I just used 1:1 and the ESC works fine in the Control Line set RPM mode. I'll check later to see for certain if that what I actually did and let you know if it is not.
John Cralley
AMA 52183
Central Illinois
« Reply #4 on: May 29, 2009, 07:50:03 PM »
Yep, I checked and I have the motor ratio set to 1.000. I have not used the "no gearing/direct drive setting." Humm, wonder if there is a bug in the new software in that regard. I don't remember if there even was an option for "no gearing/direct drive" in the old software. I loaded new firmware as well as software. Wonder if that could also play a role?
Ah well, this setting works for me so I'll stick with it for now.
John Cralley
AMA 52183
Central Illinois
  • SWE-56998
« Reply #5 on: May 30, 2009, 04:31:21 AM »
John, yes it seems to work in the 1:1 setting so I leave it there. However, I´m still curious if this has happened to anyone else.
Andreas
Nobler-O-Maniac
SWE 56998
