  • July 15, 2025, 03:04:51 PM
Author Topic: Powersystems for .15 airplane, Akromaster  (Read 25964 times)
Offline Dane Martin
  • heli pilot BHOR
« on: December 26, 2015, 11:09:25 AM »
I'm having a hard time understanding the ready set power systems for a .15 sized airplane. It seems the 3s 2200 is a common battery size for a .15? That sounds pretty big to me. An average 3s 2200 is around 6.5 oz, whereas a fox 15x is 3.5oz. Then you have a motor, esc and timer? Even a fox 35 is only 7oz. Am i missing something? Please help.
I want to make an akromaster with lights in the wings. It's getting dark early! Thanks guys
Offline Keith Renecle
Re: Powersystems for .15 airplane, Akromaster
« Reply #1 on: December 26, 2015, 10:26:31 PM »
Hi Dane,
Have a look at what I posted here: http://stunthanger.com/smf/gettin-all-amp'ed-up!/good-replacement-for-a-15-glow-engine/msg394946/
I've done a lot of work on replacing a .15 size engine with e-power. I compared the performance to a twin ball-race MVVS glow .15 and that is a pretty good little engine of medium to high performance. I was aiming at enough time for our novice stunt pattern, so I only needed a 3S 1300 battery. I would say that an 1800mAh lipo would be fine for a full pattern. Remember that a full pattern can be flown in around 5 minutes.
Keith R
Keith R
Offline dennis lipsett
« Reply #2 on: December 27, 2015, 05:30:56 AM »
I'm not an expert on electric set ups but most of my models fly with relatively small motors for the size of the model. The Acromaster will fly well with a Norvel 074 so why would you even consider using an E flite 15 or equivalent motor. It's too much for that aircraft. Think smaller. the motor designation is grossly misleading about its potential. It is more potent than an equivalent sport 15 glow as far as it's ability to develop power or turn a larger or higher pitched prop.
Offline Frank Imbriaco
« Reply #3 on: December 27, 2015, 06:18:56 AM »
 As a point of comparison: my "enhanced" Nobler ARF had an LA 46 for the first season. Nice power, for sure. Then, I converted it to electric. E-Flight Power 15. After 4 more seasons of many flights in all conditions,  I'll venture to say it has  the equal; if not more power. I've  also seen a Power 10 in a Gieseke Nobler ARF fly very well.
I'm not familiar with your ship, but set your sites to a smaller motor ,maybe a 400 series if you go electric.
Online Dennis Adamisin
« Reply #4 on: December 27, 2015, 07:40:55 AM »
You are right, weight is everything in this size range!
I fly a 1/2A Pathfinder & a Wee Duper Zilch with 3Sx1300 packs, using about 1000mah.  These airplanes are the same size as the Akro, and both are outstanding flyers.  The PF finished off at 15 oz, the WDZ at 13 oz which is also a good target weight for the Akro.  Both of these are excellent stunt models.  I demo'd then passed around the PF at the Brodak Fly-In a few years ago and people really enjoyed it.  It is amazing how deep you can go into a corner with a 15oz airplane!  The WDZ is OTS legal but I only fly modern patterns with it - seems a shame to hold it back to the Old Time Pattern.  Using .012 x 50' lines (eye to eye), but will soon be flying on Spiderwire which should be just a smidgen better:
Prop: APC 7x5EP
Motor: Arrowind 2210 kv=1560
ESC : Arrowind 18A
Pack: 3Sx1300
Timer: Hubin FM-0c
BTW, the Arrowind motor sizes are based on internal dimensions (like AXI Cobra or Scorpion) If you use a Turnigy (outside dimensions) then the equivalent size would be about a 28-28 or so.  Also key is that the kv be at least 1500 - need to spin it up.
On birds this size the enemy is WEIGHT!  Andy Borgogna built a PF using this power system (I think he changed the motor out later on) and reported here on SH that he was able to save around 1 oz by eliminating the bullet connectors, shortening the wires and soldering the motor wires directly to the ESC.  I did not do this but if I ever got around to a re-build I probably would.  BTW Andy also use the KR timer system.
There is probably a lighter battery connection than the Deans Ultra plugs too but these are handy (to me) for other reasons.  Should also mention that these are a few years old & Lipo technology has progress.  I'd bet you could find either lighter 1300's or the similar size/weight packs at 1500 mah or so.
For a hotter set-up, I also have a Jr Flite Streak that I "motored up" to use an 8x6EP prop and 3Sx1800.  It really scoots on .012 x 50' lines - like a Flite Streak should!  This one is 15.8oz.  Several folks flew this at the 2014 Brodak Fly-in and it produced instant smiles...
Prop: APC 8x6EP
Motor: Arrowind 2215 kv=1180
ESC : Arrowind 18A
Pack: 3Sx1800
Timer: Hubin FM-0c
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: December 27, 2015, 09:31:53 AM »
I'm not an electric expert either, but i would definitely not use an eflite 15 on this tiny plane! Lol i use that on a 100" glider and it's got plenty of climb.
Dennis, i get what you're saying there. But as far as weight, i planned on using the same set up as my super clown arf. Eflite 480 and a 30a esc. I think thats a 30mm motor. Too big?? With a 1300 pack, i got like 4 min. The akromaster is smaller than the clown i think. I've only built one before.
Does brodak make a motor mount conversion set for these smaller planes?? ;D
« Reply #6 on: December 27, 2015, 01:20:26 PM »
If you have an eFlight "X" motor, then they don't mean "this motor will replace a 50 year old "X" engine on 5% nitro".  They mean "this motor will replace the hottest "X" engine you can buy, running on 35% nitro or more".
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: December 27, 2015, 01:53:57 PM »
I have always respected your opinion and agreed with mostly everything you say, but in this case, i have always disagreed with what the electric motor manufactures have stated thier motor equivalents are. For example, i have used the power 60 several times. I like the motor, good quality, but it spins a 16-18 inch prop. There's no .60 glo engine i know of that does that. So to me, i would not advertise that to replace a .60. It's just really misleading i think.
But i totally understand what you're saying Tim. It's like the baddest engine you could buy in that size.
Maybe what I'll do is build it, install the led light strips inside the wing and weigh what i have going on to make a good judgment?
Thanks everyone for the replies
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: December 27, 2015, 02:08:46 PM »
Keith, excellent info there! In fact, I'm thinking that and what Dennis said proves i need to be thinking smaller. Dennis is right, an 074 would fly this thing. Maybe like Frank and Denny said, look into more of the 1/2a - .09 type power.
Excellent info everyone!
I'm thinking in the 2215 size. I'll see what brodak has. I love arrowind products. Already got plenty of timers and esc's
« Reply #9 on: December 28, 2015, 11:55:35 PM »
Hi Dane, Dennis has done more research and actual flight testing of all power systems for stunt than most of us here on this forum. Therefore his systems work! My .15 concept was trying to find an electric power package to replace a .15 engine than has a slightly better performance than the old Fox or other plain bearing .15's. I strongly believe that a .15 size stunter is a great way for beginners to get into stunt. It's not too small and not too big even for small kids to fly. In the same manner, the .09 size is just much nicer to fly than the .049, or Babe Bee size model.
Here in South Africa, I have had a fair amount of success with beginners in our Novice stunt event  and the entire pattern takes only 3 minutes to fly, so I figured that I could get away with 3S 1300 batteries which are readily available here. I did try the same motor as Dennis suggests for his Jnr. Flite Streak but it would simply not get to the required rpm to keep up with the MVVS. I had to find a motor with at least 1350 to 1400 Kv. The other point which I feel is important, is that in governed mode, you have to leave some headroom so you don't get to the same initial rpm as you would with a straight simple timer system with no governor. After a short while however, setting that high rpm up front leaves no headroom for later so the rpm will slow down. Of course the simple timers like The JMP and others do add rpm with time, so it "sort-of" compensates, but then you can actually feel it slow down in climbs and speed up in dives, so a governor system does in fact fly better even on the 1/2A stuff. If that does not bother you, then the simple timer can work for sure.
Keith R
Keith R
Offline Dane Martin
  • heli pilot BHOR
« Reply #10 on: December 29, 2015, 10:17:06 AM »
Outstanding Keith. Thank you for your help. I think i can get away with a little less power than the plane shown in your thread. It looks like yours is a little bigger physically than the akromaster?
My goal is to practise the pattern at night. Plus, if I'm wrong and it's not enough power, or flight time or whatever, my daughter will take it and fly it anyway! Putting the lights inside and having an electric plane is the main focus. If it can complete the pattern, bonus!
« Reply #11 on: December 29, 2015, 09:23:04 PM »
Yes, my model is quite a bit bigger than the Akromaster, and we mostly fly up here near Johannesburg at close to 6000 ft. ASL so we need some more rpm. Once you're done with this project please post the results with some pics of how you did the lights. It will also be interesting to see how much extra power the lights use. Thanks.
One of our C/L guys lives on a farm and flies a lot at night on a grass circle in front of his house. He put a spotlight on the roof and added some reflective tape on the inside of the nose, wing tip and rudder fin. That works well for him.
Keith R
Keith R
« Reply #12 on: January 02, 2016, 08:45:07 AM »
Sorry for the delay, wanted to get back with specifics.  This all goes back to your original thoughts about the weight of the system.  In my first reply I reference my 1/2A Pathfinder being similar sized to the Akro. Here's a tale of the tape:
                                              Akromaster                       1/2A Pathfinder
Span                                             34"                                       35"
Area                                           250 in2                                 236 in2
Fuse length                                  20.5"                                      23"
  (nose to rudder post)
Recommended Engines                15-25                                  .049-.07
Not much difference in structural weights, the Akro uses a "log" LE & TE but it also uses a 2-wheel gear.  My read is that these two are pretty much the same except for the engine recommendation.  Now if I was out to replace a 25 I would be looking at something that would turn a 9" prop and probably use something like a 3Sx2200 (or 4Sx1800) pack.  However if I was looking to replace a .049 - .07 then I would size the power system to drive a 6"-7" prop.
The difference in perception yields huge differences in weight!  In your original post you mentioned that a 3Sx2200 pack would weigh about 6.5 oz.  The complete power system I described weighs 7.1 oz.
Keith R made a very pertinent point about flying at altitude.  Out there in "Lost Wages" my GUESS is that you will have to tip the nitro uhh, I mean turn the RPM up some to compensate.  While that normally increases battery drain you are really only restoring lift & drag to levels comparable to what I see here in FTW - I think you would still be OK.
I also fly the PF at about 4.3 sec lap times and it is timed to fly the pattern with a few laps left over. That should work for the Akro too but if you were seeking to fly faster then you might want to look at a little more battery then the 1300.
BTW I designed a conversion kit for this size power system & profiles - see Brodak #BH-1935.  It should work well for the Akro and maybe save you a little fabricating time...
Offline Dane Martin
  • heli pilot BHOR
« Reply #13 on: January 02, 2016, 09:55:26 AM »
Ok, thank you very much Denny. I am ordering the eMotor mount set of that part number. I'm really leaning towards the 2215 just because of the idea of weight. I do believe my SIG kit wood is going to come out heavier than your path finder. I think you've seen a few of my Monokote ringmasters, and know i build pretty light, but I'm just building a box stock kit. Thank you for the part numbers.I'll be placing the order today
I think based on this discussion, I'm shooting for the .09 type power on this project
« Reply #14 on: January 02, 2016, 05:23:36 PM »
Not a bad plan at all!  The 2215 will actually turn an 8x6 if you want to go that far - of course that may push you into the 3Sx1800 pack.
I have an Akro started also (since 3 years ago!) but mine has all really good wood.  The log LE & TE are pretty good and the fuselage is weightless!  I am planning on the same set-up as the PF and am optimistic about achieving a similar weight.
BTW, one thing the PF has that the Akro does not: the PF is designed to use a 3" bellcrank, the Akro is designed to use a 2".  It really improves the control system if you can use the larger crank, but you have to open up the ribs to make that possible.
Yes I have admired your fabulous Ringmaster builds & 'coting methodology.  What covering will you use on the Akro to keep it light and electron-proof?
Offline Dane Martin
  • heli pilot BHOR
« Reply #15 on: January 02, 2016, 07:05:01 PM »
To keep those pesky electrons from sticking to the wing, I'll be using transparent white ultracote lite. That way the lights inside the wing shine through. Monokote covered fuse, but the color will have to be a surprise for both of us... Lol.
Thanks for the heads up on the BC. Here's what i did on an RM to make clearance. Because i had to hog out a lot of rib, i bridged not only 1and 2, but 2 and 3 as well.
I'll open the kit tonight and start checking weights. I might be surprised!
« Reply #16 on: January 03, 2016, 07:18:33 AM »
Wow, NICE job on the double bellcrank - a Ringer never had it so good!
What will the lites in the Akro weigh? Sounds more & more like a little power up may be a plan.  Also check out the Akro plan, the instructions call on cutting the LE & TE to length, but if you leave them full you can gain another 1.5" or so of extra wing span & area for negligible weight gain- might come in handy
Offline Dane Martin
  • heli pilot BHOR
« Reply #17 on: January 04, 2016, 01:12:42 PM »
Good call on increasing some wing squares. I can not find my scale. We've moved three times this past year so my stuff is just... Wherever! Lol
However from experience with these strip leds, they are extremely light. Plus I'm only using a few. If i can find my scale, I'll post the actual weights. Hopefully it'll only add about 10grams
Offline Dane Martin
  • heli pilot BHOR
« Reply #18 on: January 07, 2016, 08:01:28 PM »
Right on right on!!
Got my order in from brodak. The new motor mount conversion set up and arrow wind motor. I'm pretty excited! This should be wicked fun!
Offline REX1945
  • AMA 19945
« Reply #19 on: January 08, 2016, 12:20:22 PM »
I've built a few Akromasters and they fly fairly well at 18.5-19 Oz.  Much more than that and you can't get the pattern out at sea level.
I think the best .15 sized trainer is the (Profile) Peacemaker, sort of a 3/4 sized Flight Streak.  To me, it's the best .15 sized model around.
Rex
« Last Edit: January 09, 2016, 08:40:04 AM by REX1945 »
Offline Dane Martin
  • heli pilot BHOR
« Reply #20 on: January 08, 2016, 01:29:22 PM »
Thank you rex, very cool planes. This will be my second Akromaster. The first was not a great build... I'll admit that! Lol
I like the peacemaker. It's on my bucket list. My friend George built one, and i really liked it. But I've never flown one.
This is my third attempt at electric. The first didn't work out too good.... Lol
Offline Target
  • C/L Addict
« Reply #21 on: January 08, 2016, 07:58:33 PM »
Subscribed.
No pressure Dane, but this plane had better fly better than that RM! <=
Vr,
Chris
HNY.
Chris
AMA 5956
Offline Dane Martin
  • heli pilot BHOR
« Reply #22 on: January 09, 2016, 11:26:27 AM »
No promises Chris, but at least it will look pretty!! lol
Heres a quick video clip of prepping the akromaster for the Brodak EPS-10 system conversion
Offline Dane Martin
  • heli pilot BHOR
« Reply #23 on: January 10, 2016, 10:37:51 AM »
Installing the E-box into the fuse....
Offline Dane Martin
  • heli pilot BHOR
« Reply #24 on: January 10, 2016, 10:02:55 PM »
I guess this could turn into somewhat of a build thread. Mostly just to keep me on track and hurry up! Lol.
So the wing came out with an additional inch on each side. So 2 inch more wingspan. Thanks Denny. Unfortunately, i did something wrong or don't understand something... I ended up having to make two more ribs for the wing tips. It shows 13 on the plans, but i ended up needing 15. They are however, evenly spaced.
Pic one shows the notches that were there, and i just notched the end on the scroll saw
Pic two is just rib spacing.
Pic three is the sheeting almost done. Gotta cut the push rod exit
Offline Dane Martin
  • heli pilot BHOR
« Reply #25 on: January 11, 2016, 09:51:54 PM »
Die cut kits take A LOT of sanding! I kinda finished the wing and sanded it. I rounded the fuse and sanded it. Here's some progress pics and a fuse Monokote video is loading.
Offline Dane Martin
  • heli pilot BHOR
« Reply #26 on: January 11, 2016, 11:46:33 PM »
Heres a quick video on monokote covering the little akromaster fuse.
Offline Dane Martin
  • heli pilot BHOR
« Reply #27 on: January 12, 2016, 10:14:50 PM »
Ok, both sides of the fuse are covered and the glue on the battery box is drying while being clamped in place. I am hoping to get the wing glued in so i can start covering the wing. The "flaps" can't be installed until the wing is installed.
Offline Dane Martin
  • heli pilot BHOR
« Reply #28 on: January 15, 2016, 06:52:17 AM »
I got the wing in, and the flaps on / extended. The box says 34" wing, i ended up at 38.5"
 The wiring for the lights is almost done. I couldn't find red for my nav lights so pink was close enough.
Offline Target
  • C/L Addict
« Reply #29 on: January 15, 2016, 05:42:06 PM »
I like the high AR wing, it should turn well.
R,
Chris, who was happy to fly the Oriental today.
Chris
AMA 5956
Offline Crist Rigotti
« Reply #30 on: January 15, 2016, 10:33:59 PM »
Thanks for keeping us informed.  Keep going!
Offline Dane Martin
  • heli pilot BHOR
« Reply #31 on: January 16, 2016, 12:25:21 AM »
Thanks guys! I hope you're right Chris. I'm hoping this does the pattern well. The lights are just fun... Lol
Not much done today. I got the lights done though.
Offline Dane Martin
  • heli pilot BHOR
« Reply #32 on: January 17, 2016, 02:01:33 PM »
I spent a little time truing up the elevator halves after joining them. Took some slight shimming, trimming and sanding. Then i rounded the corners and tapered the elevators. Just for aesthetics.
I think i want to cut down the fin and rudder a little, just for looks also
Offline Dane Martin
  • heli pilot BHOR
« Reply #33 on: January 18, 2016, 08:27:27 PM »
Tail surfaces are covered. I'm just doing everything white, and then I'll add trim. I just want to get this done and flying. What used to take a day or two, now takes weeks with kids... Lol!
I'm sure anyone who knows me could have guessed... Monokote hinges. White on white, i covered the surfaces first, then just applied the hinges. Its easier than my normal method. I don't know if I'm going to say faster, because I'm using 30 hinges... I know. A little much. But it's gapless and looks cool
Offline Dane Martin
  • heli pilot BHOR
« Reply #34 on: January 20, 2016, 08:42:02 PM »
A little at a time. It's surprising how little time can be dedicated to building a kit, but it still progresses. The kids aren't interested in building every day, so 15 to 30 mins is about all i get! Lol
Offline Dane Martin
  • heli pilot BHOR
« Reply #35 on: January 21, 2016, 08:41:50 PM »
I got the rudder and fin on today. So far, I'm feeling the cg is gonna be fly-able with no weight needed for the maiden. I'm building this box stock, but i will make a CF push rod. Last one i had, the insides and outsides were different because of push rod flex.
The canopy is just sitting there to see where i like it...
« Reply #36 on: January 21, 2016, 11:40:59 PM »
Getting there!
Offline Duke.Johnson
« Reply #37 on: January 22, 2016, 08:58:35 AM »
I like the lights Dane, and I'm watching to see how this battery box works out.  I need to build another Akromaster, my last was electric, but I butchered it when I changed the motor/motor mount. I put lights in my for a night fly we had at our club field.  I'll try to find a picture.
« Reply #38 on: January 22, 2016, 09:14:27 AM »
I finally took a look at this thread.   I am amazed at what you are doing to the little bird.   Need to get my daughters plane off the hook and clean it up.   By the way this old man says there is never enough hinges,  I even put in extra DuBro hinges, especially a second one out on the ends of the flaps.
Offline Dane Martin
  • heli pilot BHOR
« Reply #39 on: January 22, 2016, 10:59:30 AM »
Thanks guys. I'll be alone tonight! That means this thing will get done. Just gotta cover the wings and hook up the remainder of the electronics. Like i said, the cg seems really good as a starting point. I just used the lead out positioning on the kit. It's stamped into the wing tip. I don't remember having any issues with that before.
Duke, do you fly free flight? Was that you i saw in the ama mag? I always flip to the back to check for control line and FF articles.
« Reply #40 on: January 22, 2016, 06:07:29 PM »
Everything is looking real good Dane.  I have been using the over/under hinges too and really like them.  I usually make them 1" wide and use them full span until I run out of surface.  Happy the CG is looking good too.
Offline Dane Martin
  • heli pilot BHOR
« Reply #41 on: January 22, 2016, 10:46:24 PM »
Thanks Dennis. So, i ran out of my transparent white. I got one wing side down, top and bottom. So I'll be making a trip to the hobby shop in hopes that they will have more. It's a little bland all white. I believe i have a lead on lettering and graphics... And I'll add some pinstriping around certain areas.
Offline Dane Martin
  • heli pilot BHOR
« Reply #42 on: February 02, 2016, 07:36:23 PM »
Ok, wings and fuse done. It took a little longer to order in the transparent white. I ordered some lettering and graphics from cfc graphics. Thanks Charles. As soon as those come in, I'll plaster them on.
Here's the lights done. Looks neat through the transparent white. Not much work left. Just some finish up and the bench trimming.
« Reply #43 on: February 02, 2016, 09:46:15 PM »
Wow, cool!  Night video is a must.
Offline Target
  • C/L Addict
« Reply #44 on: February 02, 2016, 10:33:16 PM »
I want to SEE a night flight.
(Road trip to Vegas this spring!)
Looks great, Dane. No pun intended (mostly).
Br,
Chris
Chris
AMA 5956
« Reply #45 on: February 03, 2016, 05:38:19 AM »
The trans-white is a perfect touch for diffusing the lights - what a great effect.  CFC Graphics are top notch - this is going to be a lot of fun...
« Reply #46 on: February 03, 2016, 07:31:48 AM »
Hey Dane
Yes that was me in the back of the AMA, if you have the E-version you can see the launch video.  Chuck showed up to the contest in Oregon and I spend the last day with him on the flight line.
The plane looks Great!
Offline Dane Martin
  • heli pilot BHOR
« Reply #47 on: February 03, 2016, 11:27:57 AM »
Wow, thanks guys!
 Chris, when you come out, let me know ahead of time. I'll see what we can do about rooms.
Duke, Joey Mathison wants me to come to Oregon for the regionals. I'm really trying to this year. We compete in cl speed together.
I got the esc connections and lights soldered and now I'm just mounting / cleaning up wiring details.
Details as of now,
Arrowind 2210/25 motor
Arrowind 18a esc
Hubin FM-0c timer
Hobby people 1300 3s battery
Offline Dane Martin
  • heli pilot BHOR
« Reply #48 on: February 03, 2016, 11:08:40 PM »
Well, unfortunate news. We tried to fly the little Akromaster tonight. The bell crank actually broke in half pretty quick. I've never seen this happen. My last akromaster was built with the box hardware. I flew it many many times and ended up giving it away. So the repairs are almost done. At least it looked cool for a few seconds...
Offline Dane Martin
  • heli pilot BHOR
« Reply #49 on: February 03, 2016, 11:12:19 PM »
The lead outs pulled through the ribs. Ouch!
I cut the covering off the top and cut away the sheeting over the bellcrank.
Pic 2 shows the bolt and bearing still in tact. I'm not sure how the bellcrank can just split in half like that. Oh well, the airplane was not damaged other than this. I'll be installing the SIG 3 inch bellcrank this time.
