  • June 20, 2025, 04:15:03 AM
Author Topic: Stunt Calc back up  (Read 1418 times)
Stunt Calc back up
« on: July 08, 2015, 11:30:47 PM »
I can be really slow some times.  Several months ago I got myself a domain name and whatnot just for "play business" stuff with timers and whatnot.  Then I failed to remember that I have this nifty application that's been lying fallow on my computer because I didn't have a place to host it.
So, here it is.  It's hard to use, more or less a geek's delight, and when all is said and done it'll just give you a starting point rather than a firm prediction of what you need.  Worse, the numbers are wrong for Igor's timers (but correct, I think, for Hubin and Renicle timers).  But -- here it is.
http://atomiczombieworkshop.com/stuff/stunt_calc/index.html
Have fun.  Operation is totally self-explanatory, if you're a geek.
Offline Jim Howell
Re: Stunt Calc back up
« Reply #1 on: July 09, 2015, 07:58:10 PM »
Hey Tim,
What is the "Stunt Calc" written in?  I'm running Ubuntu Linux/Firefox and I have no luck with the link.  I get one of those pesky, non-informative messages that I "... need a plug-in to run this application" with little insight into what is needed.
TIA,
Jim Howell
Huntsville, AL  AMA 545805
« Reply #2 on: July 09, 2015, 08:31:26 PM »
Sorry about that.  Java -- you need a Java plug in, or you need to download the jar file and run it manually on your machine.
Offline Jim Howell
« Reply #3 on: July 10, 2015, 12:59:22 PM »
Tim,
Got it.  And, hmmmm.... I thought I had Java plugins available and linked in.  I'll need to go poke around a bit to see what has changed in my preferences.
Jim
Jim Howell
« Reply #4 on: July 10, 2015, 01:43:01 PM »
Tim,
Jim
Since this new hosting site lets me do active web pages I should make it a .php setup that requires no special features on the user end.  I would, too -- if it weren't for pesky things like house payments and food that has to be paid for and all that.
