  • July 08, 2025, 08:38:37 AM
Author Topic: Plettenberg - SMOOOTH  (Read 1295 times)
« on: August 10, 2011, 04:30:14 PM »
run my first plettenberg motor last night - mans is that thing smooth and quiet - no more scorpions for me....
you do really get what you pay for!!!!!!!
Re: Plettenberg - SMOOOTH
« Reply #1 on: August 10, 2011, 06:37:19 PM »
Wynn,
What motor size is it and what setup are you using.
Best,        DennisT
Offline WhittleN
« Reply #2 on: August 10, 2011, 06:44:24 PM »
Wynn
Ran my first Scorpion motor last weekend - man is that thing smooth and quiet -  (SII 3026-710)
you really get alot for your money!!!!!!!
Norm
« Reply #3 on: August 10, 2011, 06:53:06 PM »
Dennis - running the 20-16 - shculze ESC - hubin timer - 5s 3000mah pack........prop - I am waiting on the new APCs form Dennis - but tried the 13 x 4.5 (original)  had a bit of tip noise -but the motor sure was sweet
Norm - the scorpions are good ( I still have 4) - but the Plett is just amazing!!!!!
Offline Crist Rigotti
« Reply #4 on: August 10, 2011, 08:39:33 PM »
Wynn
Norm
Norm,
Is your Scorpion a stock motor?
Thanks.
« Reply #5 on: August 10, 2011, 10:07:54 PM »
You guys are hopping up electric motors?  I'm so far behind.
Offline WhittleN
« Reply #6 on: August 11, 2011, 07:01:25 AM »
Howard
You are so yesterday, get with it man.  Stop engineering all this stuff and get you a honk'in motor, a hot speed control, a big battery and get out there and whip them boys!
Wynn
I have two Sultans with Plettenberg 20-16’s.  On the third one I took out my AXI and tried the SII Scorpion 3026-710 – it worked very well.  I like the 14 pole motors as they are a better match for the throttle curve on the Castle Creations ESC’s.  I was just pulling your chain; we know the Plettenberg’s are smooth as silk.  About $200 FOB Canada. Scorpion about $125 FOB North Carolina.
No, I’m getting one wound to about 680Kv but I wanted to try the stock one first.  The only fault I could find with the Scorpion is the bearings – I would definitely not rear mount this motor with only 10mm bearings.  Calculations (you know what I told Howard to stop) show the sweet spot at 680KV with 9500 RPM on a 5S battery pack.
« Reply #7 on: August 12, 2011, 10:29:55 PM »
Not really a hop up - just polishing up the ports, adding a couple head shims and then putting a chunk of wood in the bypass - you know, all the usual stuff...
« Reply #8 on: August 12, 2011, 10:55:05 PM »
Howard
Wynn
Norm,
Please keep me posted on how well it works out.  I just might have to order one myself.
Thanks.
