Electric Stunt => Gettin all AMP'ed up! => Topic started by: Matt Piatkowski on August 20, 2017, 05:38:26 AM
Hello,
I am considering Plettenberg Orbit 15-20 in the system with http://www.thunderpowerrc.com/AIR_BATTERIES/2800-mAh/TP2800-5SPX25.
Igor's 12x5 narrow blade, 11x5 wide blade or other suitable 3 blade carbon composite propellers will be used. APC 12x6 E will serve as backup.
What timers will work with Plettenberg?
What ESC is the best for this motor?
Thank You,
M
"Learning may lead to mistakes that can be corrected by more learning"
A KR timer will NOT work. Orbit has 10 poles so the KR is no good.
I used the CC Ice 50 with a Hubin timer Fm9 for years and that setup worked well.
