  • July 31, 2025, 12:32:01 PM
Author Topic: Plett Orbit 25-H Clarification  (Read 3053 times)
Offline walterbro
  • walter brownell
« on: October 30, 2009, 12:46:25 PM »
Hi Guys - I found in Stunt News that Paul walker had a new motor
in his All American Eagle. It was listed as Plett Orbit 25-H . I thought
that it was probably a 25-14 but would like some info about this motor.
does anyone know for sure what motor Paul was using and was the battery
a 5 Cell or 4 Cell ?
Sincerely, Walt Brownell
Offline Rudy Taube
  • Ret Flyboy
Re: Plett Orbit 25-H Clarification
« Reply #1 on: October 30, 2009, 01:58:32 PM »
Hi Walt,
I talked with Paul at the GS contest a few weeks ago about his motor. He now uses the Plett. Orbit 25-12  it is 770 KV. It pulls his beautiful plane like a freight train, smooth with plenty of power. Paul said he stopped using the Plett. Orbit 30-12 because it was waaaay overpowered. He uses a Thunder Power 5S CUBE for a battery. It makes it very easy to move around to change the CG.
After seeing Paul's plane fly with the 25-12, I ordered one to replace my 30-12 that is in my new project.
Paul and Dave have got to be the nicest World Champions ever. They are both easy to talk to and very helpful to all. They are always smiling and having a good time (except their serious "game face" is on during their flights  ;) ...... I guess if I had their scores I would be smiling all the time too!  :)
Regards,  H^^
Rudy
AMA 1667
Alan Hahn
« Reply #2 on: October 31, 2009, 08:30:41 AM »
During some thread about heavy electric setups (I think over on SSW), I looked up PW's setup in our setup sticky above and was really surprised to see how heavy his (original) Orbit motor was. I did wonder if such a big motor was necessary for his plane, but since I don't fly planes that large, I wasn't sure.
« Reply #3 on: November 02, 2009, 05:30:35 AM »
Walt,
Looking at the Plett site it looks like the mount for these motors is by two bolts. Can you give some details on the way these have been mounted in full size stunters.
Best,            DennisT
Offline walterbro
  • walter brownell
« Reply #4 on: November 02, 2009, 06:23:46 AM »
Hi Dennis - I do not know for sure but I would assume the two mounting bolts
were used. My first electric stunt model used a mega inrunner and it used a
two bolt mounting pattern. It weighed about 8 oz and turned a 12 x8 prop.
Sincerely, Walt
Offline Larry Wong
« Reply #5 on: November 02, 2009, 11:47:01 AM »
Rudy: Do you know if Paul use the standard mount or reverse mount on his 25-12 Plat. ? and does it have a fan?
Larry
Offline Rudy Taube
  • Ret Flyboy
« Reply #6 on: November 03, 2009, 02:30:09 AM »
Hi Walt,
I'm glad to hear your "2 bolt" system worked out OK, it gives me the confidence to bolt my motor up with 1/2 the normal # of bolts. BTW: was your 2 bolt mounting front or rear?
I'm getting close to testing mine.  My Orbit 30-12 (with the FAN) is front mounted in my CAP-21 with 2 bolts. I'm not worried much about it because it is pushing against the mount and the bolts are not under any strain, I think 1 bolt would hold it.  ;)  But my Plett Orbit 25-12 is going to be rear mounted with just 2 bolts that the motor is trying "pull" out of it's rear end! The distributor said he would reverse the shaft for me so I can rear mount. I should receive the 25 soon, I will be interested to see how they can rear mount it with the FAN on, or maybe they take it off, I'm not sure, ..... we will find out soon. I will post the results here with photos.
Hi Larry,
Sorry, I'm embarrassed to say that I forgot to get photos of Paul's motor. My friend Igor (LA) has photos and I will get them to post here. I can't believe that I looked at his motor and I can't remember which way it was mounted. This is partly due to his neat, but tight installation and partly because my memory brain cells are getting tired.  n~  My best guess is it was front mounted. Bob&Dean, and Dennis have some very neat, light, and solid methods for front mounting so I would think that Paul would do the same.
BTW: If you think Paul's flights are beautiful, you should see his fantastic planes up close! His plane is so well engineered and perfectly finished that it makes me want to park my new plane at the opposite end of the flight line!  y1
PS: We missed you at the GS contest. We had fantastic WX, great organization (thanks Jimbo), outstanding planes, and nice friends to fly with. It does not get much better! :-)  .... Eric and I had a great time. We look forward to seeing you next year.
Regards,  H^^
Rudy
AMA 1667
Offline walterbro
  • walter brownell
« Reply #7 on: November 03, 2009, 06:15:15 AM »
Rudy - My 2 bolt system was forward mounted. I think if you have a fan
on a Plett motor you must forward mount it.
Walt
Offline Rudy Taube
  • Ret Flyboy
« Reply #8 on: November 03, 2009, 04:35:29 PM »
Walt
Hi Walt,
Your right, it looks like the fan must go if the rear mounting is used. Here is the part of their web site showing just that. (I missed this part of their site before I ordered the rear mount version).
                          http://www.icare-rc.com/plettenberg_orbit_accessories.htm
My guess is that in my scale semi radial cowl, no spinner setup, the Orbit 25-12 should still run cool enough without the fan. If not I can always install my ECL "swamp cooler" idea to keep the temps down!  ;)
« Last Edit: November 04, 2009, 02:08:43 AM by Rudy Taube »
Rudy
AMA 1667
Offline Rudy Taube
  • Ret Flyboy
« Reply #9 on: November 04, 2009, 01:47:52 AM »
Update,
One of the pioneers of E-Stunt just clarified all this for me. It turns out that we can have our cake and eat it too!  y1
If you look at the link in my last post, you will see that there are TWO different FAN mounting systems. One with the FAN "AND" the shaft in front, motor mounted from the rear, ......  and one with the FAN in the rear and the shaft coming out the other end for a front mounting system with the fan in the rear.
It is a $30 part for the rear mount, FAN forward system. My friend says that he has used this method for many hundreds of "cool" flights with no problems. He says that it is a very easy conversion. And he recommends the rear mount to save weight and KIS. I will know more when I have my 25-12 in my hand and post a photo if it has the rear mount, FAN forward system. ;-)
BTW: in both cases the FAN is permanently attached (welded?) to the shaft.
I hope this answers some of the Plett. mounting questions out there. I will post some photos of my Plett install soon. :-)
Regards,  H^^
« Last Edit: November 04, 2009, 02:12:32 AM by Rudy Taube »
Rudy
AMA 1667
Offline Paul Walker
« Reply #10 on: November 06, 2009, 04:52:28 PM »
Sorry to take so long to respond.
I use the 25-14.  Prop is a 13.5 * 7 pitch.
The motor is a rear mount.  I do use the fan with this motor.
Batteries are TP 5S2P 4000.   I use up to 3200 on a flight. The colder the day, the more the drain on the battery. A really hot day at a little altitude will drop this to ~2500. Quite a variation.
Paul Walker
« Reply #11 on: November 06, 2009, 07:01:31 PM »
Paul, do you know how that Plett Orbit compares size-wise with AXI? (coummtator dia &  length)
Offline Rudy Taube
  • Ret Flyboy
« Reply #12 on: November 06, 2009, 08:23:48 PM »
Hi Dennis,
Not Paul, but this link may help.    http://www.icare-rc.com/plettenberg_orbit25.htm   (SEE BOTTOM INFO.)
IMHO: The Orbit 25 is actually small for a motor that has the power of a .50 to .75 glow (on 5S). It is about the same size as my Hacker 40.  Below are some dimensions for comparison:
ORBIT 25-12   DIA  2"         L  2 1/8"  WT  8.8 OZ. (Plus about .2 oz for FAN)
AXI 2826/10   DIA  1 3/8"    L  2 1/4"  WT  6.4 OZ.
AXI 4120/14   DIA  2"         L   2 3/8    WT  11.28 OZ.
Here is the Plettenberg web site (From Germany in English). They have all the info you need, and more!
      http://www.plettenberg-motoren.com/UK/index.htm
Rudy
AMA 1667
« Reply #13 on: November 06, 2009, 10:14:25 PM »
RUDY: Thanx for the site - was having a devil of a time finding it, could only find the ICARE site...
OK my read on the tale of the tape is that the Orbit 25-14 is (external) dims of 41mm dia x 50.5 or 45mm less fan, and 8.8 oz with kv=670.  As you noted that is a "tweener" size versus the AXI's.
In Strega  I used an Arrowind 3526, external dims are 44mm dia x 48mm length & 8.8 oz (no fan) and kv=685.
Thus the looks pretty darned close to me!
« Last Edit: November 08, 2009, 09:03:42 PM by Dennis Adamisin »
« Reply #14 on: November 08, 2009, 06:07:54 AM »
Paul,
The difference in battery drawdown in significant (looks like about 20%). When you say cooler day, at about what temperature is this and what is the range were it is relatively flat?  On the cooler days do you have a way to warm the batteries (I use an steel ammo box with separators to store and transport my batteries and in the sun it can get quite warm) or do you reduce the battery cooling air flow in any way?
Best,           DennisT
Offline Paul Walker
« Reply #15 on: November 11, 2009, 01:07:32 PM »
Paul,
Best,           DennisT
I have flown it as cool as about 35 deg F, and as hot as ~100 deg F.
No change in cooling. On the 35 deg day, the battery didn't feel like it got to even 100 deg F. On the Hot day, about 120 deg F (measured).
There feels like there is a significant increase in the drag on the plane in those conditions. The control effectivness is certainly increased. At the same RPM, the prop will make more thrust, and that is balanced by higher drag. If flies at nearly the same lap times in those two conditions.
I'm not sure what you mean by "flat".
The "drawdown" is variable by at least +/- 100 mah for any given day and temp.
