  • July 11, 2025, 11:31:17 PM
Author Topic: blank  (Read 713 times)
blank
« on: June 22, 2013, 06:34:31 PM »
blank
« Last Edit: September 08, 2021, 10:23:37 PM by Motorman »
Offline William DeMauro
Re: Please Suggest a Prop
« Reply #1 on: June 22, 2013, 07:14:19 PM »
That plane can easily be flown with a power 15, 4s 3000-3300 mah batteries and an APC 11x5.5 pusher prop at around 9800-10000 rpm on 60' lines maybe even longer. Save the power 25 and the 4000 mah batteries for something a little bigger.
AMA 98010
« Reply #2 on: June 23, 2013, 04:16:17 AM »
yes you can use the prop I suggested and possibly even smaller batteries than the ones I first suggested if its built light enough. you will have about a 3-4 oz weight penalty.
AMA 98010
