John;
Here's the electric power set up:
Motor - KDA A22-20L
ESC - ZTW 30 amp with BEC
Timer - KR Governor
Battery - LP2200 3S 25C
Prop - APC 9X6EP
All connectors are soldered on for you. The entire system is bench tested prior to inclusion in the kit. All programming is already done (RPM, start delay, flight time, gain <that's the electronic tuned pie effect>).
All you have to do is to build the P51, mount the power system, charge the battery, flip the switch and fly. Like everything else we offer this product is guaranteed to work properly. If it doesn't we will repair what's wrong, replace the product or refund your money!
Eric Rule
