  • June 26, 2025, 12:57:40 PM
Author Topic: Prop slip on motor shaft  (Read 3324 times)
« on: February 10, 2023, 09:01:44 AM »
I am having a tough time getting props tight on the front mount BadAss 5mm shaft. I am using a typical collar clap-on prop mount. Has anyone found a method to prevent slippage when tightening down?
I was thinking that maybe taking a cutoff wheel and roughening up the shaft might do it but would like to hear what others have done.
Best,     DennisT
Re: Prop slip on motor shaft
« Reply #1 on: February 10, 2023, 10:55:06 AM »
Best,     DennisT
I have had the same problem.  What I am doing now is pre tightening the prop nut so that I have to use moderate force to get the collet onto the shaft.  It seems to hold just enough for me to get the prop nut to grab.  It was so bad when I was using Cobra motors that I put a hole in the bottom of the cowl so that I could slip an 1/8" wood dowel into it and hold the can just enough to get it started.  My biggest issue though was the spinner.  I use plastic because, well I am cheap, and the backplate and prop alignment was always off.  On a profile, I just hold the can.
Online Fred Underwood
« Reply #2 on: February 10, 2023, 11:37:08 AM »
1/32 ply disc CA'd to the back of the prop.  I only have had problems with Carbon props and the ply disc fixed it.
Fred
352575
Offline Frank Donnelly
« Reply #3 on: February 10, 2023, 12:47:41 PM »
I think we are talking about 2 different issues. One is the collet slipping on the shaft, the other is the prop slipping on the collet. I had the first issue with a Badass motor on a 5mm shaft. One of my flying buddies, Ken Cook, told me to spray the shaft with some accelerator or wipe it with alcohol. I thought that was a little crazy but he has never steered me wrong. I tried it and it work instantly, the collet grabbed on to the shaft with no slippage.
« Reply #4 on: February 23, 2023, 08:36:57 PM »
Might be like the supre tigre , where any grime defunctionalises it .
Maybe washing all the pieces in solvent would let them key up .
« Reply #5 on: July 14, 2023, 02:20:03 PM »
What I finally found that works on my BadAss 2320 motor is to slip a very thin (wheel collar size) allen wrench through the back of the motor (away from the windings) to hold the motor can from turning, then tighten the prop nut. This has worked completely and did not damage to the motor.
Best,    DennisT
« Reply #6 on: July 14, 2023, 06:16:31 PM »
Best,    DennisT
I do the same thing.  On my 3520 in my PA ship I have an access hole in the bottom of the cowl to let me slide the wrench into the slots.  All it takes is for the collet to grab just a little then you can tighten the hell out of it without the wrench in there.  Another thing that I have found that works is to sneak up on it then give it a quick quarter turn, almost a snap, while putting some side pressure on the prop right before it figures out what you are doing so it can't turn the motor shaft into Teflon. ???
