  • August 03, 2025, 11:43:51 PM
Author Topic: Overheat Shut Down?  (Read 747 times)
Overheat Shut Down?
« on: October 26, 2012, 03:54:50 PM »
blank
« Last Edit: September 03, 2021, 12:03:29 PM by Motorman »
Offline Bob Hudak
Re: Overheat Shut Down?
« Reply #1 on: October 26, 2012, 08:16:33 PM »
More than likely it is shutting down from over current. An amp clamp on one of the motor leads can guide you, or you can look at the logged data if you have the type of speed controller that allows this.
 Bob
350838
Online Crist Rigotti
« Reply #2 on: October 26, 2012, 08:38:09 PM »
Remember when running it on the ground, there is a lot more "load" on the system and you could burn up your motor/system if you are not careful.  My system uses a 12 x 4.5 prop and uses about 1800mah when flying, on the ground I use a 8 1/2 x 6? prop to simulate the flying load.
