  • June 20, 2025, 03:19:50 AM
Author Topic: Outrunner Animation  (Read 707 times)
Outrunner Animation
« on: February 15, 2013, 01:05:30 PM »
I thought folks might be interested in seeing how the internals of a motor works.
Here's an animation of a 4-pole outrunner turning (you have to click on the thumbnail for the animation to start up).  The outer arcs are the business ends of the permanent magnets, the oddball-shaped inner pieces is the armature.  Red means a north pole, blue means a south pole, gray means an armature segment isn't energized.
Study it for a while, and you'll see that each armature segment switches polarity in a way that means it's always pulling a permanent magnet in the right direction to make the motor spin -- this is how the motor generates the torque it needs to keep the prop going.
Re: Outrunner Animation
« Reply #1 on: February 15, 2013, 05:32:51 PM »
Good one Tim, thanks!
I did my own variation of "Outrunner animation" the other night at the Indy Sportliners Club meeting.  I was doing an intro-talk on electrics, with the motor running I was cranking up the throttle pot, tryig to show the range of the throttle.  Unfortunately I did not have the prop TIGHT enough and..... well it was animated for a few moments!
« Reply #2 on: February 15, 2013, 05:42:30 PM »
I'll bet that some of the audience were pretty animated, too, for a bit.
That's one way to encourage the audience to pay attention.
