  • June 20, 2025, 02:26:03 AM
Author Topic: Hoby King G series (Easy Match) motors  (Read 2889 times)
Offline Horby
« on: October 01, 2014, 01:00:58 PM »
Is any one using the easy match Hobby King motors? I just got a G15 I am going to see how it compares to my E-Flight. So far I have over 100 flighs on my E-flight with out an issue. (Front mount)
Cheers,
Warren
Offline Jim Damerell
Re: Hoby King G series (Easy Match) motors
« Reply #1 on: October 01, 2014, 03:48:05 PM »
I have been using a G25 in my 66 oz. Cosmic wind with no problems. The G series has fewer poles the E-flight, so governor settings will be different.
Offline Horby
« Reply #2 on: October 02, 2014, 12:14:14 PM »
Thanks for the heads up, how does it compair with power consumption?
Warren
Offline Robertc
« Reply #3 on: October 02, 2014, 02:08:44 PM »
I tried a G25 a couple weeks ago and was too fast with the same ESC setting I used on the AXI 2826/10.  What settings are used for the G25?
Offline Steve Hines
« Reply #4 on: October 04, 2014, 01:52:32 PM »
We have used the G15 it is ok, but we like the Tacon from hobby parts better, the 15 and the 25 are the same weight. So we have started using the 25, and it is 172g.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #5 on: October 04, 2014, 06:22:39 PM »
I noticed the wire gauge was stiffer and different as compared to the E-Flite motors. I have had two G25's go bad, and ended up replacing them with the E-Flite E25
There is also a very slight bolt hole pattern difference between the two mounts
I liked the quality better on the E-Flite motors and have since stopped buying the G series motors
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Horby
« Reply #6 on: October 05, 2014, 08:57:54 AM »
I just had a day of flying on my primary force with a G15 and a 55A Trust esc.
It ran flawless, the battery didn't get warm, the motor was cool on a 3min flight.
The  battery used was a 4s 2800, and I had to put 1000mA back in.
I was using a 11x 5.5 at 9650 rpm at 5 sec laps on 58' lines. I have to say I was impressed by the esc and motor. For the price you can't beat them.
Warren
Offline Horby
Re: Hoby King G series (Easy Match) motors update
« Reply #7 on: December 12, 2014, 07:25:45 PM »
I managed to fly my PF on the full pattern before the winter set in. I am sold on the Easy Match motors. The power consumption is low, power is great and works every bit as good as the higher priced equipment the others I fly with. Next season will be the litmus test when I start using my set up hard with practicing and competition.
Warren
