  • June 18, 2025, 10:53:12 PM
Author Topic: programming  (Read 858 times)
Offline paul winter
programming
« on: June 18, 2013, 12:13:49 AM »
hi all
does anyone have a copy of the Pdf for programming Keith Renicle timers ,please
pw
Offline Keith Renecle
Re: programming
« Reply #1 on: June 18, 2013, 01:27:06 AM »
Hi Paul,
The original is in MS Word format, but I can send it to you pdf as well. Just drop me an e-mail and I'll send it to you. In case you've lost my e-mail, it's krenecle<at>netactive.co.za.
Keith R
Keith R
Offline paul winter
Re: programming
« Reply #2 on: June 18, 2013, 06:14:05 AM »
hi Keith
pleased your on ,question can your timer allow my motor to do more than 11000 revs
im running a 8.0/950 mvvs ,4c3700 35c battery ,your timer and a castle 50amp esc what do you think ?????
paul@psautos.freeserve.co.uk
Offline Andrew Borgogna
  • Andy
Re: programming
« Reply #3 on: June 18, 2013, 11:26:47 AM »
I just sent you and Keith an email.  I believe I have been to around 11.5K on my Flite Streak slow combat plane.  If you still need the instructions let me know I can send you a copy as well.
Andy
Andrew B. Borgogna
Re: programming
« Reply #4 on: June 19, 2013, 09:02:15 AM »
Hi Paul,
I just mailed the manual to you in pdf format in case you need it. The manual says that the rpm can be from 7500 to 11700, but it will work to more than 12000. I can make it work over that too if necessary. I just figured nobody would need to run that fast, but it is possible,
Keith R
Keith R
