  • July 17, 2025, 08:43:40 PM
Author Topic: On Off No Off  (Read 2593 times)
Online Motorman
On Off No Off
« on: August 04, 2016, 11:53:43 AM »
Hubin timer FM9v, external push button with CC edge light 50 esc.
Found this out during ground crew safety drill.
Push the button and get the warning spin for 30 sec count down. Push the button again at 20 sec and motor still starts as normal at 30 sec. Button does not stop the count down. After 30 sec as the motor is running push the button and motor stops. Is this normal?
Any time arming plug is in, hang on to plane which is what saved the day.
Re: On Off No Off
« Reply #1 on: August 04, 2016, 12:03:01 PM »
Hanging onto the plane any time the battery is connected is in the rules.  That's why.
Re: On Off No Off
« Reply #2 on: August 04, 2016, 02:53:20 PM »
On all the timers I use, the only way to really RESET everything is to disconnect the battery (or pull the arming plug)
Offline Bob Hudak
Re: On Off No Off
« Reply #3 on: August 04, 2016, 04:38:26 PM »
No it's not normal. Time to replace intermittent normally open button switch.
        Bob
350838
Online Motorman
Re: On Off No Off
« Reply #4 on: August 04, 2016, 09:02:12 PM »
It's a new switch and it seems to work consistently. Does yours stop the count down?
Re: On Off No Off
« Reply #5 on: August 05, 2016, 09:43:57 AM »
mine does instantly.  I would check the new switch with a multi meter.
Online Motorman
Re: On Off No Off
« Reply #6 on: August 05, 2016, 02:31:26 PM »
I have 4 Hubin FM9 timers and they all do the same thing. I don't think you guys are reading the OP.
Online Motorman
Re: On Off No Off
« Reply #7 on: August 05, 2016, 02:32:48 PM »
Ground crew has been re-trained to wait until prop is turning to shut it off with the start button because, it won't shut it off before then.
Offline Bob Hudak
Re: On Off No Off
« Reply #8 on: August 05, 2016, 09:15:33 PM »
When I push the button it stops the countdown, it will also stop the motor if it is already running. Maybe your ground crew isn't hitting the button all the way? 4 timers is unusual to have the same issue(but not impossibe). I would check the buttons and if no problems check the ground crew.
Bob
350838
Online Motorman
Re: On Off No Off
« Reply #9 on: August 06, 2016, 07:37:09 AM »
I have an electric test stand for breaking in batteries and I tested each one myself several times. It's not operator error.
Re: On Off No Off
« Reply #10 on: August 06, 2016, 02:03:24 PM »
O.k,   I misread the part the button was pushed before the start up.   as I just tested it, and it does not stop it from starting.  But any time after the start up it will.   So I assumed it is normal.
Offline Bob Hudak
Re: On Off No Off
« Reply #11 on: August 07, 2016, 01:26:01 PM »
I put my system to the testnand found it wil only stop the motor when it is running, not when it is in the timer starting sequence.
350838
